Author Topic: Soundbridge 3118 SWF  (Read 3958 times)
Steve Shafer
« on: November 27, 2004, 06:37:38 pm »
Hello:
Has anyone had hands on experince with these subs?  They seem to be quite reasonably priced.  However, the ouput graph seems a bit suspect to me.  I am told that eminence is the SoundBridge OEM for the cone drivers.  Does any one out there know what a good street price would be and how well these boxes are constructed.
Thanks
Steves
Here is the link:
http://www.soundbridge.com/pdfs/3000pdf/3118swf.pdf
Specifications
Frequency Response: 30hz-300hz
Power Handling: 1000w (cont.)
Sensitivity (1 watt/meter): 106dB
Nominal Dispersion: N/A
Impedance: 4 Ohms
Transducer Components
Low Frequency: 18” woofer
High Frequency: None
Audio Input Connections: Two Neutrik Speakon connectors
and two parallel jacks.
Enclosure: Vented
Crossover: None
High Frequency Protection: N/A
Steel Pole Mount: No
Physical
Dimensions (H x W x D): 36.25” x 24.25.” x 36.25”
(92.1cm x 61.6cm x 92.1cm)
Weight: 166 lbs./75.5 Kg
peter.golde
Re: Soundbridge 3118 SWF
« Reply #1 on: November 27, 2004, 11:09:52 pm »
With a logo like that how can you not believe the specs?
"You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer" - Frank Zappa
[x]
« Reply #2 on: November 28, 2004, 11:22:45 pm »
Well, their stuff definitely looks the part. They're probably just a victim of an overcrowded market where the stuff needs to be really exemplary in order to get noticed at all. That response graph probably employs multiple boxes. One horn is generally not enough.
I've said and written things in the past that I wouldn't throw away in my own trash can for fear that you'd find them. My name is mud.
Page created in 0.035 seconds with 21 queries.
