Hi tempa,
Sonic has been making that box for a loooong time. It is basically what is known as a Keele design W. As a matter of fact, I have 4 of them sitting in the old barn at Too Tall's farm for the past 2 1/2 years or so - since I completed my first pair of LabSubs. The Sonic is a reasonably well made box - decent grade of plywood (not Baltic Birch by any stretch) and rat fur covering. When they first offered the box, I believe the upgrade option was a Gauss, then EV EVM series II then EV ProLine. Now I suspect as Eminence has expanded their line and their power handling, the 600 watter is probably an Eminence. The biggest problem with the design is that in standard use at one per side, they qualify as a 'one note wonder' which is to say, it is very efficient at about 62hz and not a lot else comes out. As you build them up to an array - for instance using a 2x2 stack of four, the larger horn mouth does improve response and smooth it somewhat. I believe they claim usable to 40hz in an array of 4 boxes. At a sensitivity of 102db 1w/1m, you would calculate a maximum output of about 129db at 600w but that doesn't take power compression in to account. My caution to you would be that you would need about 16 of them to compete with a single 2x2 array of LabSubs. I can't speak for the Eminence driver, but my friendly local EV reconer and I became fast friends (your best customer tends to become your friend in any business!!)
HTH,
Al
