Hi Graeme.
I think that going from a 12" to 15",immediately requires a larger horn,although with the same length,it goes slightly lower.
Throat area has to be re adjusted,meaning the horn is probably twice the area at the start,making it larger,not even including the larger Vrc etc.
Do you think,that the small rear box contributes to significant 2nd harmonic distortion at bass frequencies,like linkwitz suggests on sealed boxes? Or are the 2nd harmonics,atleast in the upper bass not transmitted effectively through the large Vtc.
Or is the distortion products mainly due to driver BL nonlinearity?Youd think so ,because the passband is so narrow,and near the increased Fs(fcb i guess)due to small Vrc. Why not use a driver with both SFG and shorting rings to help out these areas? As you know,my 2226 has these,and Il be building,and measuring(have to save for ECM8000)
What about Sven,he thinks that the labhorn has a rubber throat-is this true? if so,does this contribute to lower system distortion?
Cheers!
