FWIW,
We have been using a Roland VM-7200 digital console in our church for about 18 months and have had excellent results with it. As of last year, it is no longer manufactured but you can find them used on e-bay. We recently purchased a used second system with 2 processors (40 inputs, 12 aux sends) and a full complement of outboard A/D-D/A converters (which gives us a total of 96 inputs, each with eq, and compression plus 48 direct outputs) for $4,000. The reason for the second system was to build a road kit and to prepare for an additional sanctuary. This also gave us some redundancy in case we do have support problems (that is the obvious downside of buying gear that is out of production).
We would have loved to buy a PM5D or even a DM2000 but the reality was that it just wasn't going to fit our budget. Instead, we chose to focus the budget dollars on acoustic consulting and speaker selection/placement. Those things are much harder change/fix so I'd like to do them as well as possible. In our case, we knew we could use a lower cost mixer and still do everything we needed to do. As often happens, we had to make a compromise that could fit our budget and still meet our needs. This board has done that well for us. Is it the ideal mixer? No. Are we happy with it? Absolutely!
I echo all of the comments regarding learning curves for digital mixers. It will take some time to get used to. Our operators took anywhere from two weeks to two months to get comfortable with the features they need every week. Even after 18 months, only two of us are really familiar with all of the boards capabilities. That may seem like a problem but I could have said the same thing about the Mackie SR24-4 we replaced. Some people just want to know enough to get by; I'm not happy until I have a schematic in my hand.
Having scene presets is wonderful. We have three seperate service configurations across 5 different services and moving from one to the next is as simple as pressing a button. That button restores every preamp gain, fader level, aux send (all 12 of them), eq, and compressor to the place they need to be. We may still have to tweak a setting here or there but that's much easier than setting 40 levels across 13 busses.
Being able to recall scenes also makes it possible for a great operator to create a starting point for a newbie. Our operators seem to learn faster when they aren't immediately overwhelmed by all of the settings that need to be made for a contemporary service with a full band. Learning a little at a time seems to work well.
I have to say that this forum is a great place to get ideas and share experiences. I always learn something when I check in but the thing that always strikes me is that one solution does not fit all. Looking at the other posts, it appears you have several options. Your job is to find the one that fits your church best.
