Many of you may recall that I had sent a requisition to Eminence for an improved subwoofer that would work in the LABhorn. Eminence has decided that the device would be cost prohibitive to build at this time. They would be willing to consider continuing to work on the project if 1000 pieces were ordered and a substantial price paid to them to re-tool. Otherwise, they are not particularly interested in adding the larger flux ring required to reduce distortion at low frequencies. That leaves other options to consider, for any of you interested in an improved version.
My interest was always in making improvements that would decrease distortion of the motor assembly prior to the throat. Many of you were also asking for increased thermal limits and improved power handling ability. My thinking was that even though a horn will reduce excursion, reducing distortion at the motor will increase performance even more. And since the lowest octave is unloaded, distortion products rise dramatically and harmonics enter the horn to be amplified by it. For all these reasons, I put a great deal of focus on the motor chamber itself. For the deepest frequencies, improvements in the system as a direct radiator are important, in my opinion.
The biggest benefits of having an improved woofer would be that it could be used to retrofit existing speakers in the field. When drivers were damaged, they could be upgraded during the repair process. Having a woofer with a shorting ring large enough to stabilize the flux at low frequencies would reduce distortion in existing designs.
But there is another way to do it, and I'd like to hear your comments in this regard. With two drivers being used, they can be connected in a push-pull configuration so that they pressurize the front chamber with opposite sides of the cone. A positive pressure would be created by the front side of one cone and by the rear side of another. Any asymmetries caused by flux modulation would then cancel in the front chamber.
This approach can be used with the LAB12 to improve its performance, particularly in the area of low frequency distortion. A person can configure the horn so that back chamber, front chamber, horn length and cross section area all are made appropriate for the LAB12 and take advantage of the push-pull arrangement. Distortion should be reduced across the board, with the largest benefit seen at the lowest frequencies where distortion rises the most.
It's really just a matter of turning one driver around and connecting it so that the cones pressurize the front chamber in phase. The reverse-mounted driver must be reverse-connected. The horn layout might be easier to realize when made shaped as a "W" like shown above, so that the motor chamber fits nicely. But it's not a terribly difficult proposition, I don't think.
Another alternative is to use a different driver and optimize the horn dimensions for it. There are many 1000 watt woofers to look at, so that's something to consider. I'm looking at each of these options, since Eminence has decided to hold off on the B12. But with all the response I received from each of you, I'd still like to look at other options for drivers and/or configurations for a high-power, low-distortion alternative.
Please see the thread on this subject at
www.AudioRoundTable.com/ProSpeakers/messages/137.html. I would appreciate your input.
