Author Topic: HPF vs. vented box tuning  (Read 1453 times)
Andres Gonzalez
« on: November 02, 2004, 05:23:48 pm »
In all of my calculations, it shows that the x-max is reached with in a few hertz of the vented box tuning. The minimum excursion happens at the box tuning, then shoots way up fast as you go down in freq.  My question is this:  what should your high-pass frequency be set to given the box tuning?  The high-pass I use is usually 24 db/octave butterworth. But if my box tuning is for example 36 Hz, what high pass should I use to insure that I do not exceed the maximum excursion?
thanks,
gonzo
Michael_Elliston¶
    • http://www.geocities.com/xobt
Re: HPF vs. vented box tuning
« Reply #1 on: November 04, 2004, 04:10:23 am »
I cant tell you because i dont know the Power,Xmax,Fb,Vb nor driver specifications.
Considering that having the -3db point of filter AT the tuning would just result in slightly lower output at tuning (only just audible) then this isnt a bad place to start in theory.
Try a 'couple of hz' lower.
winisd pro + update can model FIlter + subwoofer alignment and show excursion (beta)
www.linearteam.dk
Cheers
Page created in 0.035 seconds with 21 queries.
