Author Topic: Construction Order of Horn  (Read 3707 times)
Michael_Elliston¶
    • http://www.geocities.com/xobt
« on: October 08, 2004, 12:58:51 pm »
Hi all.
Ive built Designed and built my own basshorn in the past but it was only a little 40hz 150litre cornerhorn.(btw it functions well in the house and sounds great(in the car too Razz)And also my 7cube jbl box,which is all easy ofcourse due to being BR.
The wood was cut perfectly by the joiner,but i fudged it up.Its still airtight but the panels are off a few mm in places.I assembled it all at once using screws and glue only.
My problems with my little horn is,When i was going around laterally from the throat chamber,i didnt drill the baffles in from the side panel so they were slightly skewed-i think i should do each panel from the side as i do it.
(http://www.geocities.com/xobt)
Question-
In what order would you assemble things.
Ofcourse the critical things is the Throat chamber-so i should start there yes.
I know the typical idea is to draw around the parts when their in the right sport,predrill,Draw the parts on one side panel turn it over,predill that side and it should line up with the baffles inside.(mine didnt on the little horn due to me not attaching them to the side panel til id done ALL The internal baffles!So i know  NOT to do that..
Just thought that perhaps some one experienced could give me a pointer!
example attached for the  build order in alphabetical order..
Brad Litz
Re: Construction Order of Horn
« Reply #1 on: October 08, 2004, 05:36:13 pm »
mike_nz wrote on Fri, 08 October 2004 11:58
In what order would you assemble things?
See http://home.comcast.net/~labhorn/notes.txt
and http://www.geocities.com/hulkss/page3a.html
Assembly order depends a bit on the details of your joints.
Brad Litz
Michael_Elliston¶
« Reply #2 on: October 09, 2004, 08:31:23 am »
Thanks brad..Il start from the throat since thats the most important and must be accurate-while expanding around it in a circular fashion like the labhorn
All my joins are just butt joints,this horn is for home use,18mm MDF with 18mm MDF bracing with swiss cheese holes in it.
Driver is jbl2226
raj
    • http://-
« Reply #3 on: October 11, 2004, 01:09:00 am »
Mike
could we know more about the example1.PNG attachment in your post ??
Is it suitable for PA ?
RL
Michael_Elliston¶
« Reply #4 on: October 11, 2004, 10:18:06 pm »
Hi raj
That horn is a smaller mouthed,long path exponential approximation,with 33hz horn tuning for the horn.F3 is near 28hz
The idea was to get nice fun lows in the home.
1 in a corner 2 against a wall or 4 in half space
It could well be useful,maximum SPL is excursion limited with the 2226 in the midbass area.
Note that not all types of music warrant in pro usage require 33hz output,and a 42hz tune is much more useful,practical,efficient.
If you have a certain requirement send me a PM
Cheers!
raj
    • http://-
« Reply #5 on: October 13, 2004, 12:29:48 am »
Mike
You mean that it will NOT make MUCH DIFFERENCE in the overall
sound ( in pro sound ) if we use 40hz horns, with a low cut at
40hz , is this it
RL
Michael_Elliston¶
« Reply #6 on: October 17, 2004, 05:09:00 am »
yes thats it.
Page created in 0.038 seconds with 18 queries.
