Stevesb65 wrote on Mon, 18 October 2004 00:43 |
I saw this horn and phase plug kit and thought it would be a good starting point for a top box.
http://www.proaudioparts.co.uk/index.php?id=pornhorn
"Porn Horn"??? Pleeeeeeeeze! LOL
This is a bit different approach then what has been suggested on the forum. What would be the upside and the downside of going with a mid driver assembly like the one above
my .02
Steve S
Hi Steve,
Well lets take it case by case.
IMHO a single 12" front-loaded is a nice box for the install market and small bars, but not the BEST match for the LAB subs. The 12" is hopelessly outmatched by the sub and the 2". It's not a bad box, just not a good match. It's only advantage is weight, which can be the most important consideration if you are by yourself setting up a PA.
Using a true horn loaded mid-bass means the horn is going to be BIG if it's going to reach down to 80Hz and mate with the LAB. If you can stand that it will be a good match, but I would not present it as the solution with the broadest appeal. It works best as part of a 4-way design.
Were I to design a top box for the LAB sub with the tools I have available I would go with a two 12" woofers and a 2" horn. Either MTM if the top box is just a 2-way or TMM if the top box can be filtered to make it a 2 1/2-way. The bottom 12" would only sees low mid frequencies. It is only there to help with the 80Hz to 250Hz range.
I might play with a wave guide on the 12" and some partial loading. IOW part of the 12" drivers are covered by the horn throat giving it a mild compression ratio and changing the dispersion.
This was done on a box a friend designed and I built 20 years ago and it still stands up as a solid box. With the tools available today we would actually be able to model and check the design to some degree instead of blindly trying different box designs.
My next fall back design would be a single 15" and 1" horn. This would have more reach in the low-mids, while not breaking the bank. The design fails or stands on the 1" driver and horn.
The horn needs to be bigger rather then smaller and the 1" driver needs to be "robust". Add some steep and well placed filtering and you have a powerful box. This is what Al uses for monitors and even though they use passive xovers and no time alignment they perform quite well as monitors and on a stick as mains with the LAB subs.
Their drawback is they are fairly large even for a 15" box. The larger horn is responsible for this, but you CAN'T cheat the horn size and have it work well with a 15".
Too Tall
