Chris,
I have 2 LABs, and 4 of these tops, and it seems like a good combo for the type of work I do. But I don't operate at real high volumes, and the LABSs are not even stressed, even with some heavy EQ, so I think you could throw even more tops (say pairs of double 12s or 15s each side) into the picture.
The Magnum 12HO drivers are really heavy, and not as efficient as I'd like so I am going to be trying out some B&C drivers shortly.
As to cost, its all in the drivers, and I leaned towards the better stuff on these, so they are not exactly cheap. You can lower costs by going with cheaper components and moving down to a 1" horn.
As with anything there are some compromises going on here. You need to cross the LABs over at around 100Hz minimum, as the bottom starts to drop off after that on these tops.
--Peter
