ALthe mtl are mod-ed to make 1 8 ohm circuit. so I drive 2 sub cabs with 1 amp. I did a show with them this weekend and they did o.k., they didn't shut down but on the first test run of the amps my face probably looked like this guy
Elliot ThompsonA Few Things I've Noticed
1. By you using the series-parallel scheme, you reduced
the speakers sensitivity.
2. By using 2 PLX 3402's, speakers wired in parallel,
oppose the series-parallel scheme, you would'nt have
loss the sensitivity.
Why don't you rent another RMX 5050, and use the same
speaker configuration as you would do with 2 PLX 3402.
But to be honest, you are only gaining 2 dB's more,
using 2 RMX 5050's -vs- 2 PLX 3402's
IMHO, I don't see the RMX 5050 at fault here.
Best Regards,
