Author Topic: Speaker wire to span utility poles outdoors?  (Read 17620 times)
Don Goguen
    • http://folkcafe.wordpress.com
« on: July 11, 2004, 08:57:55 am »
I need to spec wire for a voice only system outdoors at a camp.   I'm replacing/upgrading an existing system that has had many problems over the last few years.   The average span between poles is approx 300 to 400'.
Any ideas on what wire to use?
Most of my work is indoors so this is a bit new to me.  I usually only have to figure out if I need plenum or not.   Fortunately I won't be the one that has to run the wiring as the camp has staff including an electrician that wishes to do the work.
Thanks
Don Goguen
Karl P(eterson)
Re: Speaker wire to span utility poles outdoors?
« Reply #1 on: July 11, 2004, 02:56:45 pm »
I am speaking a little out of turn here seeing as I don't have a lot of experience in this field (overhead line suspension) but I do have a little bit of clue, and thus will throw in my thoughts (which may be worthless).
There are two ways to do this. One is to use an Industrial twisted pair control cable, and using metal straps of some sort secure it to a steel cable which is then secured and tensioned to the poles.
The other, easier, and more correct way of doing it is to use variable lay twisted pair overhead suspension phone wire. These cables normally come in a minimum of 6 pairs and three common guage sizes for this wire are 24, 22 , and 19 (at least in what I have seen). I don't know what distances you are running, but you will probably want 22 guage, but do your own math on that one.
With that wire (an example here) You buy the wire, special clamps which secure to the messenger wire and the pole(S) and whatever splice boxes you may need.
A warning: This stuff is not cheap, but is designed to last and engineered to work in these type of environments. In any case, I would probably recommend transformer isolation and line drivers on any sizable run.
Again, consider the source of who this came from, but maybe it will give you some help.
(If you are curious about the company I showed you, It is just a site I found through Thomas Register, and there "main" page is here. There is a telephone number you can call and get pricing information on the cable, splices (if needed), mounts, etc.)
About multiple pairs - you probably want them anyways, for any future expansion, paging, maybe a remote phone? Etc.
Karl P
Karl P
steve g
« Reply #2 on: July 12, 2004, 03:58:27 pm »
Hi Don.
You'll notice, if you've ever watched your cable or telco that for single wire runs, like a drop to your house, they use a cable with a built-in messenger.  For single runs, it makes sense, because you simply run and secure the wire via the messenger.  However, for multiple runs or runs where they want to be able to add more cables later, like runs down main streets, they will run their messenger lines, then come back and pull their cable bundles along side of it and all of that is then secured by a "mesh" that finally secures all of the cables together with the messenger.
It sounds like for your application, you will probably benefit most from a cable with a built in messenger, where everything is on one spool and you run it, secure it, DONE!  Karl also had a good idea of running the cable and attaching it to a simple messenger line.  This effectively would do the same thing in an additional step.
Hope this helps.
Steve
Hal Bissinger/COMSYSTEC
    • http://www.comsystecusa.com
« Reply #3 on: July 12, 2004, 07:45:27 pm »
Been down this road before back in the old forum. This is the relevant reply I gave, you can check it all out here: http://www.prosoundweb.com/community/read.php?board=2&id =150095
____________________________________________________________ ___
Ok. The cable is referred to as IMSA spec cable. It's used for traffic light wiring. I see that there is a 2 conductor 14 ga (I'm assuming that 14ga is sufficient here) messengered cable available. (Messengered cable is also called self supporting aerial or figure 8 (what it looks like when looking at it from a cut end)). This cable is not twisted pair but I suspect that it does have some twist to it. The only thing I don't like is that it has a 1/4 inch stranded messenger. I had hoped for something with a 12 or 10ga solid messenger. 1/4in is a bit of a bear to work with. You cut it with bolt cutters and it's flooded with a tar like stuff so you have to clean it off before pushing it into the dead end grips. Not a big deal though once you get used to it.
What I suggest you do is give Clifford of Vermont a call (1800-769-1837) and ask for their catalog. Though Belden makes this also, I believe Clifford has this cable in stock and will cut and ship whatever length you need. (They might even be willing to send you a sample of the cable so you can see if you are up to this). They also stock all the pole hardware. All you need is a "J" hook to screw into each pole and the building and some 1/4in "Strandvise" dead end grips to hang the cable, 2 per pole and 1 at each end.
At each pole separate the strand from the cable by cutting the web with a knife, cut the strand, clean it, stick the end of each strand in a deadend and hang them on the "J" hook. The cable itself should loop at that point with some slack. You can make this slack as long as you want to connect to a speaker by just stripping more of the strand and cutting it back. You could almost do this on the ground then go up and hang it. You just have to get the sag right so it looks good with the other cables. The dead ends are ratchets, the strand can be pulled through easily to pull the cable tighter. Let go and they tighten up to keep it there. Where the cable enters the building, strip the strand away and discard it for whatever length you need after you attach it to the building with a "J" hook and dead end.
...then come back and pull their cable bundles along side of it and all of that is then secured by a "mesh" that finally secures all of the cables together with the messenger.
Steve, that's not mesh. It's called lashing wire and is put there by a lasher. Lashing is normally done for most large aerial installations because most cables are designed to be installed this way. There are a limited selection of self supporting "messengered" cables.
Lashed construction consists first of hanging a steel stranded "strand" along the cable route on each pole. Once this is secured in place the cable or cables are pulled and positioned below the strand with temporary hangers. Then a lashing machine is placed over the strand and cables at the start of the run. The lasher is pulled along between the poles on a rope attached usually to the stringer bucket truck that the crew is using but it could also be pulled by hand (or a horse Laughing) if you can't drive a truck along the route. The lasher has one or two spools of steel wire attached which it winds tightly around the strand and cables as it's pulled to secure them to the strand. At each pole the lasher has to be taken off the cables and strand, moved to the other side by the guy in the stringer bucket and the process repeats. Lashers cost about $1000 if you are wondering.
If this isn't more information than anybody should need, ask some more!
-Hal
steve g
« Reply #4 on: July 13, 2004, 12:51:54 am »
Wow!  Thank for all the info, Hal.  I didn't try to go into this and further because I figured the guy was just looking for a quick solution to his simple aerial runs of speaker wire, and didn't want to leave him really confused, but hey.  That's cool.
In a totally unrelated question... maybe it's just me but it seems like sometimes people ask really simple questions about other things on this board like, "what's an edison plug look like?", of course my first idea would be to show them a simple picture of the two vertical blades and a ground prong.  But a lot of the time, you will hear stuff like "well, the NEMA # for THAT connector is..." Well hey, the simple jist is two vertical prongs and a ground prong.  Remember, they asked "what's it LOOK like".  I dunno, just a thought.  I've kinda noticed this over time.  I guess it never hurts to include some extra info anyway...   Very Happy
Hopefully all our info has helped this guy on his way...
Steve
steve g
« Reply #5 on: July 13, 2004, 01:07:35 am »
Hal Bissinger/COMSYSTEC wrote on Mon, 12 July 2004 18:45
Ya, Hal, where we're at we like to have fun.  Most people around here use four wheelers... Hell Ya...
Don Goguen
Thanks Guys
« Reply #6 on: July 13, 2004, 08:10:23 am »
My Google searches were getting nowhere.  I knew someone here would be able to help.  Thanks Hal. You had the exact answer to my question "what kind of cable?".  My suppliers were just scatching their head at my request.  I'll give Clifford a call and price it out.
Thanks again all.
Don Goguen
Vince Byrne
« Reply #7 on: July 13, 2004, 09:33:44 am »
globalaudiovideo wrote on Mon, 12 July 2004 23:51
Quick question to all... maybe it's just me but it seems like when sometimes people ask really simple questions on this board like, "what's an edison plug look like?", of course my first idea would be to show them a simple picture of the two vertical blades and a ground prong.  But a lot of the time, you will hear stuff like "well, the NEMA # for THAT connector is..." Well hey, the simple jist is two vertical prongs and a ground prong.  Remember, they asked "what's it LOOK like".  I dunno, just a thought.  I guess it never hurts to include some extra info...   Very Happy
Steve,
Problems come come when a question implies that someone is about to try to do something that they really don't understand and can run into safety or legal problems. If someone is asking about wiring a distro and doesn't know that an Edison plug is a NEMA 5-15P then they almost certainly have NO BUSINESS acting on wiring advice from here, and the only responsible advice to give is to send them to a licensed professional or to a company that sells agency approved, professionally built systems.
Responsible answers to questions don't just answer "how" and "what", but also "is this wise?", "is this safe?" and "is this legal.
Let's say your buddy here is able to take the responses from the LAB and wire up this system fully compliant to code.
He still would not be well served if he were to follow "our" advice, only to have the local utility rip down his wiring and have him cited for doing the work without proper licensing, permits, and inspections. I'm not saying that is going to happen here, not my field, but your buddy should certainly know what he's getting into before sinking his time and money into this.
Confused  Confused  Confused Question:
Quote:
I'm wiring a distro. What does an Edison plug look like?
Smile  Smile  Smile Responsible answer:
Quote:
Hire a professional to wire your distro so you will meet code, be legal, and not kill anyone. No, really, you ain't got the knowledge and skillz to do this safely and legally. BTW, an Edison plug is a NEMA 5-15P which has two vertical prongs and a ground prong.
Shocked  Shocked  Shocked Irresponsible answer:
Quote:
An Edison plug has two vertical prongs and a ground prong. Have at it, mate!
Peace,
Vince <><
steve g
« Reply #8 on: July 13, 2004, 11:31:07 am »
Hey Vince, how are ya?  Ya, that example you described is much different than, say, "a guy told me that his amps all have edison plugs."  "Guys, what's an edison plug look like?"  So ya, the situation you described is definitely not what I was referring to.  In that case, yes, you would WANT to be much more detailed because they are asking for the info... and if they're building a distro, they better already know about the terms you're using, eh?  Very Happy
Thanks
Steve
Vince Byrne
« Reply #9 on: July 13, 2004, 12:22:04 pm »
globalaudiovideo wrote on Tue, 13 July 2004 10:31
Thanks
Steve
Yup, that all works. And for "a guy told me that his amps all have edison plugs."  "Guys, what's an edison plug look like?" an answer like "the usual three prong thingy that plugs into the wall" is probably as good as it needs to be.
But you do need to know when you are handing someone a loaded gun or a loaded piece of advice. If it's loaded you need to have some idea that they aren't going to hurt any one ...
Peace,
Vince <><
http://www.hubbellcatalog.com/wiring/explorercat/straight%20blade/images/hbl5266c_diagram.jpg
Page created in 0.049 seconds with 18 queries.
