Author Topic: Alesis, Samson, or others????  (Read 3305 times)
tedtf
« on: June 16, 2004, 12:31:51 pm »
Looking for some good quality, quiet amplifiers to run some mids in home studio setup.  Don't want to spend a ton of dough.  I have seen these amps quite a bit.  Alesis 150, 300, and 500.  And Samson 170,260, and 550.  Any experiences?  How well do they do into 4 ohm loads also?
Mike Sveda
    • http://www.cohglory.org/Sunday@7/index.html
Re: Alesis, Samson, or others????
« Reply #1 on: June 17, 2004, 09:48:50 am »
I'd rather buy USA made Carvin at that price range
tedtf
« Reply #2 on: June 17, 2004, 11:30:59 am »
I want something quiet....how loud is the fan on Carvins?
Karl P(eterson)
« Reply #3 on: June 17, 2004, 01:24:14 pm »
Assuming this will be for home use, how many channels do you need? On the home side Outlaw Audio makes some very nice and reasonably priced amps in mono 5 and 7 channel. In commercial sound, QSC and Crown make some good multichannel amps.
For what its worth,
Karl P
tedtf
« Reply #4 on: June 17, 2004, 03:09:09 pm »
I will be using the amp to drive 2 2118Js per side.  Yes-home use.  The speakers I built are these drivers top to bottom-2118J, 2404H, 2118J, 2226H, 2226H.  I call them the fridges.  I use a plx 3402 for the 2226s.
Karl P(eterson)
« Reply #5 on: June 17, 2004, 05:36:32 pm »
well, noise will be an issue with the plx3402's so you may want to take a different tact here....
Would you consider using a D-75A, and three K1's?
Run your 2404H on each side one side per channel on the D-75, double up your 2118's on each side and run the two drivers on one side of a K1. Then double up your 2226's and run a K1 in bridge mode for each cabinet.
Quite and good power matching for all the drivers. Oh, and the loudest frickin fridge you've ever heard.
Karl P
Page created in 0.045 seconds with 21 queries.
