Author Topic: LSP dxf files converted for use with 18mm plywood  (Read 6274 times)
Jeremy Bridge
« on: June 04, 2004, 12:55:26 AM »
If anyone is interested I have completely conveted the dxf files located on the LSP documentation for use with 18mm plywood (metric).
We have build 4 subs with 8 more on the way so I know the conversions are right Smile
I have also added a batton so that you can put a grill on it if you like.
It might make things a little easier for some.  Especially those using a CNC router and converting the files for use.
Just e-mail me if you would like a copy.
David Haulman
Re: LSP dxf files converted for use with 18mm plywood
« Reply #1 on: June 19, 2004, 07:44:27 PM »
Could I get your updated design for lab sub. I just realized that I had the 3/4 plywood printed out. Thanks Homer
David Trotter
« Reply #2 on: June 29, 2004, 06:12:15 AM »
I would love a copy of those files as i am in the Uk and we only have 18mm and use metric.
Do you have them in PDF too?
cheers mate
dleet_83@yahoo.com
Cred
    • http://www.diyaudio.com
« Reply #3 on: June 29, 2004, 10:28:26 AM »
I was about to start construction of Labsub Ver.3.0 in a couple of days.  I would be very grateful to have a copy of the 18mm drawings.
Thanks,
Sam
mail me at: cred@rediffmail.com
Sam
raj
    • http://-
« Reply #4 on: June 30, 2004, 01:39:27 AM »
If you put up the 18mm drawings on the forum it will be useful to all
RL
Ernie Black
    • http://www.standingstone.com
« Reply #5 on: June 30, 2004, 11:32:29 AM »
Jeremy has sent me the drawings and I have posted links to them on the LSP Documentation page. Enjoy!
Ernie Black, Code Warrior
ProSoundWeb Forums Webmaster
Jeremy Bridge
« Reply #6 on: July 01, 2004, 12:01:23 PM »
Ernie I am going to PDF them at work tommorrow as well, that way everyone can open them Smile
But the link to the 3rd drawing is not working??
Ernie Black
« Reply #7 on: July 01, 2004, 02:31:24 PM »
Fixed now, Jeremy. It was a file naming issue: you had named drawing 3 as Lab_ and the others as LAB_ and I didn't notice this; since the names appeared to be the same except for the number, I simply copied and pasted each filename in the hyperlinks and changed the number accordingly. (Unix convention, don't you know: case sensitive, unlike Winders, so the system looked for LAB_18mm_drawing_3.dwg and didn't find it.)
Good show on the PDF's, send them to me when you get them done and I'll put them up.
raj
    • http://-
« Reply #8 on: July 07, 2004, 01:19:00 AM »
Dear Ernie,
I have sent you the drawings by Mr Jeremy Bridge  in pdf format by e-mail I hope you got them
RL
Ernie Black
« Reply #9 on: July 07, 2004, 09:11:00 AM »
Yes, and they are now posted and linked from the LSP Documentation page. Thanks!
Page created in 0.031 seconds with 21 queries.
