Basically you can't do quite what you're proposing.... Since each track powers *all* the lights physically attached to it you can only control *all* the lights on that track. You could do a very 1980's 'Van Halen' look; banks (or stips in this case) of individual color...
Now to your DMX question. DMX is short for DMX512, which is a data communications protocol used by lighting controllers ("dimmer boards") to talk to the dimmers themselves. Think "midi" for lights. The lights themselves (except for the fancy moving things) don't give a darn about DMX (or AMX, or analogue, or LMX, or....). Except for those moving lights, lights themselves don't directly receive DMX data.
I'd suggest you investigate some truss-mounted dimmers like Lightronics or Leprecon. If you are going to use these in a reasonably permanent way, you'll have electrical code issues to deal with (you can't just string extension cords to power the dimmers, for example) and you may want to check into "architectural" dimming designed for permanent installation. Lightronics can be your friend here, too.
And now a bit of unsolicited advice/commentary: in most any installation of lighting, the lights themselves are the least expensive part of the package (until you get into the moving lights/scrollers, etc.). The big money is spent on making it legal (those pesky life safety codes, electrical and fire) and aesthetically pleasing at the same time. Mundane things like conduit, wire, circuit breakers and panels. BTW, your pastor's track lights are probably
NOT UL APPROVED for stage lighting, and if they were to cause an electrical fire your church's insurance company could deny the claim based on mis-application of the lighting fixture. This would, as they say, suck.
I know that churchs seem to be continually strapped for cash (esp the ones on TV
) but you need for the fundamental parts of this to be done right, both the electricity and the actual attachment of the lights to the structure of the building.
I'm not trying to scare you or anything, but when you start hanging objects over people, or running electricity hither and yon, you are doing things that can kill or maim people if done incorrectly. And I think most higher powers disapprove of such things.
Regards,
Tim Mc
