Author Topic: Anyone remember "Stagecraft" lights?  (Read 2161 times)
Chris Condon
« on: May 20, 2004, 02:47:11 pm »
They are no longer manufactured, but were a really cool portable (and I mean SMALL!) set of lights with a footswitch controller.
It was basically two boxes a little bigger than a toaster. each box contained 3 or 4 lamps (RGBY). they were stand-mountable and perfect for tight spaces and tiny stages.
No one seems to make anything like them these days. the closest thing is the "Color Bank" by Chauvet. Unfortunately, it is sound activated only ARRRGGGHH!
Any ideas for really small setup? I have 8-par cans on T-bars, but even that is too big for the venue we play regularly.
Thanks!
Chris C.
www.dial9music.com
Dan Glass
Re: Anyone remember "Stagecraft" lights?
« Reply #1 on: May 20, 2004, 03:14:37 pm »
I know that Lightronics makes a foot controlled par 38 setup.  I think they call it the L-11.  You can add on an additional stand and lights to "expand" the system.
I hope that helped
Dan Glass
Dan Glass
Adam Feldstain
    • http://www.pro-opticlighting.com
« Reply #2 on: May 21, 2004, 12:22:24 pm »
Chauvet now also has something called the stage wash its RGB and its got barn doors and DMX. its 1500w and small and inexpensive!
http://www.chauvetlighting.com/system/fixtures/stagewash.htm l
index.php/fa/100/0/
Adam Feldstain
Pro-Optic Lighting
djallf AT djallf DOT com
Will Sanders
« Reply #3 on: May 21, 2004, 04:16:08 pm »
MBT Lighting also has something simalar called the Port-A-Four which is a parcan with four lamps (RGBY).  Each lamp is only 250 watts.  You have to use a seperate dimmer to control them.
Will Sanders
« Reply #4 on: May 31, 2004, 03:48:18 am »
I had to put on my tennis shoes to jog my memory around the block Wink
IIRC there were marketed by Rapco, known primarily as an audio cable and assembly provider, located in S.E. Missouri.
I have no idea if they still sell them Sad
HTH
Tim Mc
Page created in 0.053 seconds with 19 queries.
