and another few things...
i understand overlapping the LAB's to the double 15" and i understand why i have to swich polarity (can also set phase to 180 on the DSP), but how about overlapping the top's with the 3 dual15" ?
To have a complete view here are the top's:
per side will have 5 top's now
3 tops are with same Eminence K15LF as the dual15", they are crossed passive to 600Hz. Do i let the double 15" go the same up? I want to let this 3 top's down to 40 Hz too, to help on the low end...
The other 2 tops have different 15" (Delta 15) that can do maybe 50Hz and are the same crossed at 600Hz to the mid.
Do you think i should let the double 15" on the ground or do i put them on the metal structure below the top's ?
Isn't it more fun to tweak a low budged system like this ?
I think i would need some good knowledge in smmart to get a decent sound out of this combination.
And yes i have a DSP (B. DCX2496) for each side, working together on LAN and controlled with my laptop, so we have 6 outs per side to play with
Thank you and sory for the complications and my poor English
Bogdan
