Church and H.O.W. – Forums for HOW Sound and AV - Your Displayed Name Must Be Your Real Full Name To Post In The Church and HOW Forums > H.O.W. AV
Projector Screen Install in Gym CONTINUATION
Jonathan Johnson:
--- Quote from: Brad Weber on February 17, 2011, 07:30:43 AM ---These types of issues are easy to miss. I remember one job where a couple of the techs came and grabbed the Project Manager and myself saying "You have to see this." They take us up to a divisible meeting room and point up. There was a nicely framed opening in the wall above the operable partition through which another tech had run all the cables. What he apparently didn't realize is that the framed opening was a smoke damper that is intended to close and keep the spaces separated during a fire. Oops.
--- End quote ---
And any cables that do pierce a firewall need to be properly installed with an approved firestop and sealed with fire-rated sealant. Your local codes may vary.
http://en.wikipedia.org/wiki/Firestop
http://www.ask.com/wiki/Sheetrock#Fire_resistance
Kristian Stevenson:
--- Quote from: Jonathan Johnson on February 28, 2011, 08:22:42 PM ---And any cables that do pierce a firewall need to be properly installed with an approved firestop and sealed with fire-rated sealant. Your local codes may vary.
--- End quote ---
Thanks for that info Jonathan. None of our cable runs went through a firewall so we are good there.
Navigation
[0] Message Index
[*] Previous page
Go to full version
