Author Topic: Pastor is Too Loud!  (Read 7485 times)
Jacob Robinson
Pastor is Too Loud!
« on: February 07, 2011, 12:32:51 pm »
Hello to all and I want to thank this site for the wealth of knowledge over the past couple months, but now I am her to make my first post.
I run the sound for a small church (130 attendees on an average Sunday) and I am having issues with my pastor/ future father-in-law.  He is a very lively speaker and likes an extremely hot monitor mix, the problem is that his voice is so loud without any added microphone that when i do add in the mic for recording purposes the congregation gets blasted (sanctuary size 30' x 75')
Currently I turn his mic almost all the down and the send to the recorder(Tascam CD-RW900SL) all the way up, this works, but it produces a very distant and quiet sound because there very little mic pickup available before it becomes too loud in the church.  We have an ancient 25+ yr. old peavey board with no aux sends.
I hope I gave enough info for you to understand my situation, any thoughts on how to produce a better recording without introducing more volume to the church would be great.
Tom Young
  • Global Moderator
Re: Pastor is Too Loud!
« Reply #1 on: February 07, 2011, 01:04:23 pm »
Talk about "between a rock and a hard place"   :(
What are you trying to record: the sermon, or something else (as well) ?
If it is the sermon (and therefore just the pastor's mic), you need to split this from the primary mix that is feeding the sound system. Obviously.
You said there are no aux sends. To be clear: there is no effects send and no monitor send on this mixer ?
Is there a direct output from each input channel (on the rear) ?
Tom Young
Electroacoustic Design Services
Oxford CT
203-888-6217
Jasen Jacobsen
« Reply #2 on: February 07, 2011, 01:11:46 pm »
This sounds like exactly the opposite approach to take. You want a strong clear signal going into the board. Then you want a soft signal going to your amps/front of house speakers. And a strong signal going to your recorder.
You don't provide much info on your board, but there should be a way to separate the level coming into the board from the level going out to your speakers and recorder - typically an aux send. You mention monitors, so perhaps you could use a monitor send to send to the recorder. Strong signal in, low signal to stage monitors, high signal to recorder "monitor", low signal to mains.
- Jasen.
Jacob Robinson
« Reply #3 on: February 07, 2011, 03:50:48 pm »
We record the etire service, music and Sermon,  We get as many requests for music recording as sermons
The mixer does have two monitor sends, but we have a full worship band that might string me from the nearest tree if I took one of there feeds and used it solely for recording.  But maybe I am overlooking a configuration that would work.
I believe the mixer is a Peavy 16/21 (not sure of specific model number) this is the way I currently have it setup
This is the setup I inherited and have never had the motivation to drastically change, but now that I am learning more my motivation for change is rapidly growing.
Below is the list of sliders that are being used
16 mic inputs
"Mon A" (Music & stage monitors)
"Mon B" (Music & stage monitors)
"Left" (main output that is not used at all every channel is faded all the way to the right)
"Right" (this is the output to the main house speakers)
"Master" (this is used as the send to the recorder)
The problem I have is that whenever the "Right"  is turned down nothing is sent thru the "Master"
in short, it appears as thought the "Master" channel is dependent on "Right" channel
Something I just thought of as I was typing, What would happen if I used the "Left channel" for recording.
Tom Young
  • Global Moderator
« Reply #4 on: February 07, 2011, 06:17:01 pm »
As long as you have Left and Right outputs along with the Master output, then yes: this will work. Or at least better than you have now.
Use the pan controls. Pan the pastor's mic channel to 12:00 (center) so it is going to both the Left and Right submasters. Pan everything else to the Right *only*.
Using the pastor's channel fader and the pan control will allow you to keep him mixed in the sound system and where you need him for the recorder. It'll take some tweaking.
Tom Young
Oxford CT
203-888-6217
Scott Raymond
  • Nebraska
« Reply #5 on: February 07, 2011, 06:18:21 pm »
That may well be a viable option.... The master likely just sums the left and right channels and if you don't need it give it a whirl.  You can bring in the channels you need by panning them towards center to get them to your recording.  It may take some trial and error to get everything sounding good but at least you keep you house mix at the level you need and get the record level up more.
« Last Edit: February 07, 2011, 06:21:09 pm by Scott Raymond »
Taylor Phillips
« Reply #6 on: February 07, 2011, 07:08:28 pm »
One thing you could also try a hard disk recorder, like the Zoom H1 for instance,
and not take up any of your board outputs.
Jacob Robinson
« Reply #7 on: February 07, 2011, 08:39:08 pm »
I will give that setup a try on Sunday and let you guys know how it works.
Thanks again for all the quick responses I look forward to learning more as I keep exploring the site.
Jasen Jacobsen
« Reply #8 on: February 08, 2011, 10:38:58 am »
16 mic inputs
Hmm... Excuse me while I think through my fingers.
So your signal path looks like:
mic -> channel in -> pan & fader -> left & right -> master
You have mono outs on left & right, and mono out on the master.
You MIGHT try switching the Right and Master outputs. Send the Master to the mains and the Right to the recorder. That way you could have a nice strong signal all the way through the board to the Master and attenuate the signal to the mains using the Master out. The Right out (split, I'm guessing to L&R in on the recorder) would feed a strong signal to the recorder.
Make sense?
If that works, you could get fancy and do a stereo mix of everything. Use both the L & R outs to the recorder and pan the band around to your heart's content. Since the Master out is mono & summing the L & R you shouldn't notice any change there.
Jacob Robinson
« Reply #9 on: February 11, 2011, 09:01:48 pm »
I ended up panning every channel to 12 O'Clock and then using the right channel for the mains and the left for the recorder.
I tried using the right for the recorder and the master for the mains, but this resulted in a feed to the house speakers that was dependent on the level that was being sent to the recorder.  With the config of using the left for the recorder and right for the mains I can now change the record level completely independent of the mains, and vice versa. . . does anyone see any issues with this, I have yet to try it in a service
Thanks,
Jake
Page created in 0.313 seconds with 24 queries.
