Electric Violin signal path suggestions
<< < (2/3) > >>
John Halliburton:
--- Quote from: Eric Christian on February 06, 2011, 10:59:44 AM ---I'm looking for some ideas to improve the sound of the electric violin in our band.  She's currently running direct into the PA through some cheap effect pedals(mainly reverb, delay, and wah) and a Whirlwind IMP DI box.  We get a useable signal but its somewhat harsh and sterile sounding. I'm currently using a lot of eq to help with this.
We've discussed using an acoustic violin instead but her electric is a 5 string and she like not having to worry about feedback problems with the electric as well.
My first thought is to use something like an Avalon U5 or some kind of tube preamp and get a better reverb/delay pedal for her.  We borrowed a Presonus Eureka channel strip for a few shows and that was an improvement though not phenominally better.  Any suggestions of gear to look at/try without getting to crazy expensive?
Thanks!
Eric
--- End quote ---
Your thinking of an Avalon U5, but then state suggestions that aren't too expensive?  Guess my definitions are different than yours.
Anyway, the first thing to ask is what kind of five string electric violin and bridge pickup does she have?  We need to start here.
Fairly typical of the breed is a need to drive the signal off the bridge into a tube preamp or really good solid state preamp first.  I have found that a moderately priced tube preamp like the ART MP series provide a good match to the typical piezo bridges for violins.  My Countryman DI's provide a good match too, but there is a drier sound to the fiddle.  Overdriving the inexpensive ART product a bit provides some of that tube "magic" that does warm up and take some of the dryness out of the sound.
That said, I regularly see some players showing up with cheap electric fiddles, routing them through a handful of foot pres/fx made for electric guitars, that no amount of board tweaking can help.
Best regards,
John
Eric Christian:
--- Quote from: John Halliburton on February 06, 2011, 09:37:21 PM ---Your thinking of an Avalon U5, but then state suggestions that aren't too expensive?  Guess my definitions are different than yours.
Best regards,
John
--- End quote ---
Thanks for all the info everyone!
The violin she's playing is a Yamaha EV 205.
http://usa.yamaha.com/products/musical-instruments/strings/el-violins/ev_205/?mode=model
So its somewhat of a quality instrument at least.  The main reason to stick with the electric versus an acoustic violin is for the 5 string.  She does use effects quite a bit so getting a natural violin sound isn't exactly the goal though something warmer sounding than what we have now is.
I've seen Avalon U5 sell used for around $400 so while definately not cheap its still in a reasonable price range considering we're a regularly gigging band and its worth it to us to purchase quality equipment as long as it fills our needs.  By crazy expensive I was think more so of the high end studio preamps/channel strips that sell for $2-3000.
I've seen the ART Tube MP as well as a Presonus Tubepre that are both quite affordable and easily available to try so I guess we'll give those a shot first and see how it goes.
Roland Clarke:
I wouldn't waste your money on expersive pre's etc, its the old case of garbage in, garbage out.  The problem with these "skeleton" stlye electric violins is that they have no real body resonance wich tends to give them a very "dry", harsh sound.
The most effective solutions I've ever come across are the specialized pickups connected to a dedicated DI box with built in eq, I'm guessing as this is the Yamaha one that isn't an option.  In this case I would recommend using a standard DI box and careful desk eq to get the best out of it.
As mentioned by a previous poster, add the effects afterwards.  If necessary, get the player to use an acoustic amp for onstage sound (they can add a little of their own reverb and tailor the sound to their own requirement) and use quality outboard to add effects FOH, post the desk EQ.
John Halliburton:
--- Quote from: Roland Clarke on February 07, 2011, 09:41:39 AM ---I wouldn't waste your money on expersive pre's etc, its the old case of garbage in, garbage out.  The problem with these "skeleton" stlye electric violins is that they have no real body resonance wich tends to give them a very "dry", harsh sound.
--- End quote ---
Roland and Eric,
More to the point, the Yamaha is not quite the quality instrument you think it is, period.  Roland, there are definitely minimalistic body type electric fiddles that are very good sounding electric instruments:
Jensen violins:
http://www.halcyon.com/jensmus/violin.htm
Jordan violins:
http://www.jordanmusic.com/
They are just two of many.
However, Roland's suggestion of wasting money on downstream electronics that cost more than something like the ART Tube MP preamps is well heeded.  Until she gets a serious instrument anyway.
Another type of instrument to see about is an acoustic electric five string.  Barbera in New York makes a line using acoustic five and six string bodies built for the job, and mounting one of his great pick up bridges.  BTW, Barbera and Baggs bridges are the two I always recommend after 20 years of monkeying around with them.  Both Jensen and Jordan spec Barbera bridges as standard on their instruments.
Eric, my suggestion is that you get her and her fiddle to a store to try one of the ART tube preamp products(or something similar), and go straight into a channel on the mixer into your system.  I'll wager two things.  First, all the cheap pedals corrupt the sound quality of a mediocor instrument, and second, it will sound better.
BTW, an acoustic fiddle set up with either bridge pickup routed through a tube preamp will have boatloads of gain before feedback with good sound quality-I often suggest setting up a sweet sounding fiddle that may not be a suitable solo acoustic instrument(not a great acoustic projecting fiddle) with a bridge pickup into tube preamp.  The combination produces a very nice set up that gets plenty loud.
Best regards,
John
Jay Barracato:
--- End quote ---
The images in the Fishman aura line are not bad. I would go that way before I would invest in any other type of pre amp system.
I have gotten good results from the yamaha violins using a Radial PZ Pre, but cost wise that is overkill. I already had the unit.
Another good brand of electric violins is NS designs.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
