Author Topic: advice on covering large outdoor area  (Read 6409 times)
Brian Muth
« on: August 23, 2011, 10:58:02 pm »
I'm doing a band event outdoors on a patio that's maybe 70x150ft total including crowd seating. It has close to zero lighting,and is a dark hole at night.  I place  a 4x par64 led tree on each side of the band and it covers the small stage area wonderfully.
Here's where I need some advice:
For a high dollar fundraiser there, they will be doing an auction from the stage. I've been informed that it needs to be well lit... duh... but the issue is that the auctioneer needs to see the crowd (he can't be blinded by lights), so they want the entire crowd area lit too... BUT with NO ONE "blinded" by lights in their eyes.... this seems pretty tricky to me since I can't put lights entirely above their heads in the ceiling that doesn't exist! Basically they want it to be like an indoor setting, very bright but with no visible lights...
I'm looking for any and all advice on the subject. I expect the answer is in a quantity of dimmer lighting as opposed to fewer/bright lights. I've got a total of 12 ledpar64 currently, and six of the 9ft trees. I know the par cans have fairly narrow patterns, and expect they're the wrong light for the job... I'll spend some money here on additional lights. but would need advice on how to best spend the money-obviously the cheaper the better!
As for the par cans...Perhaps some diffuser gels to mellow out the cans?  How about some uplighting, is there any benefit to that?  Any experience with battery powered led cans?
I really appreciate the advice guys. I need it!
JBL Vertec VT4888 over EAW SB1000
Still got the KF850's too
Yamaha M7 and a few Midas M32's
Lab gruppen PLM20000q and QSC 4.3, 4.5
...and then a handful of VRX make the money!
James Feenstra
Re: advice on covering large outdoor area
« Reply #1 on: August 24, 2011, 01:31:49 am »
uplighting won't really light up the crowd
your best bet would be to see if they'd rent a tent to cover the event that you can hang lights off of and/or light up so it disperses the light over the crowd
failing that, can you build a truss box around the crowd to do crowd lighting from the top? it's unlikely that you'll be able to light everything without some light being in someones face
Elevation Audiovisual
www.elevationav.com
Taking your events to the next level
Stuart Pendleton
  • Colonial Yorktown, VA
« Reply #2 on: August 24, 2011, 08:47:19 am »
We have rented lights for something similar.  Not sure what the unit is called.  It is a pull-behind generator with tower for two large lights, similar to what road crews use for working at night.  we had it brought out for a backyard party for a group of wealthy boaters that wanted the yard and docks lit by the water while we played.  It would cover the area fairly well.  Not sure what the rental cost was.
John Moore
  • "learning the hard way sucks donkey kong"
    • Trinity Productions
« Reply #3 on: August 24, 2011, 01:58:18 pm »
they work very well, but are quite noisy running, since they are not muffled very well.....mostly seen on the freeway for night construction.
if you can get the lights up high enough, some 500w halogen type work lights would be sufficient. and would not be that blinding if you can get 14-16 feet in the air..
http://www.trinityprosound.com 209-832-8023
DEALER:Dealer for Yorkville, EV, QSC, RCF, Danley Sound Labs, VTC, Allen & Heath, Ashly, Denon,  Audix, One Systems, Beyerdynamic, Presonus, K&M, Ultimate,  Trusst, Road Ready, Gator, Radial Engineering, Turbosound, dB Technologies, RCF, American Audio,  Rapco, CBI Cables, ADJ, Chauvet, Blizzard, Furman, Shure, Tascam, Elite Screens,  BenQ, Midas, Digico,  and many many more...
John Livings
  • Los Angeles, California
« Reply #4 on: August 24, 2011, 02:12:14 pm »
Have you considered having an Electrician give you an estimate to install a permanent sub panel with output options?
Sometimes the cost is close to that of generator rentals, without the Noise or set-up time.
Find out what the total load might be for lights, sound and..., double that and get a bid.
I don't know your set up, however if this is next to a commercial building or power, this could be an option.
Regards,  John
Brian Muth
« Reply #5 on: August 24, 2011, 11:49:44 pm »
Thanks for the answers guys. As I thought, getting them up in the air as high as possible is gonna be the key. They aren't going for the expense of tent/ trussing. Of course... they didn't get to be members of a ritzy club by spending their money, did they?
There's plenty of power to be had on site, so that's not a concern. It's good to hear others confirm the things I suspected... exactly what a forum like this is designed to do!
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #6 on: August 28, 2011, 01:20:19 am »
Maybe rent some crank up lifts and put some 500w pars up there?
I am sure any large A/V rental place will have both.
Tim Padrick
  • Indianapolis
    • T.P. Audio
« Reply #7 on: August 28, 2011, 03:29:27 am »
Rent a blimp to hover over the site, and hang lights on that :-)
g'bye, Dick Rees
  • Duluth
« Reply #8 on: August 28, 2011, 09:08:28 am »
Have bidders signal the auctioneer by using their cell phones as signal lights.
Tim Palmer
« Reply #9 on: August 29, 2011, 02:47:19 pm »
Do the gig in the daytime
