Author Topic: M7CL Limiter for Aviom channels?  (Read 1957 times)
Anderson Schulle
« on: August 21, 2011, 12:18:44 am »
Our FOH console is a Yamaha M7CL with an Aviom card.
Most of our musicians run wired headphones into their individual Aviom units.
Is there a way to put a limiter type of compression on each Aviom out channel, that would prevent a signal from going past a certain threshold?
  • Old enough to know better
  • Audio Plumber
Re: M7CL Limiter for Aviom channels?
« Reply #1 on: August 21, 2011, 01:03:19 am »
Not without effecting either the input channel dynamics, or the mix channel dynamics. There are no processors on output ports except delay.
If you were using an Aviom input box instead of the card you could put a limiter between the console direct or mix out and the Aviom input. You cannot do that with the card.
Aaron_McQueen
« Reply #2 on: August 21, 2011, 04:00:50 pm »
You could run every channel through a mix and then compress each mix.  But then you would be out of mixes.  What are you trying to accomplish by doing this?
Anderson Schulle
« Reply #3 on: August 22, 2011, 02:44:51 pm »
Thanks for the responses!
The main purpose would be to protect our ears from crazy peaks that have occasionally happened due to a musician's hot signal, or the sound engineer's mishap with the knobs. This is not a recurring problem for us, but it has happened before.
Page created in 0.066 seconds with 24 queries.
