Author Topic: Sennheiser md441 on vocals?  (Read 16575 times)
Airton Pereira
    • The Knutz
Re: Sennheiser md441 on vocals?
« Reply #10 on: August 09, 2011, 11:47:49 am »
I know, but if I have to increase the gain level due to the high impedance, it would have more bleeding, right?
Drummer and Sound Engineer for The Knutz.
« Reply #11 on: August 09, 2011, 11:48:39 am »
No.  The ratio of direct sound to "stage bleed" remains the same.
Airton Pereira
    • The Knutz
« Reply #12 on: August 09, 2011, 12:00:56 pm »
Thanks for helping!
I was afraid when I read Glasvegasīs foh enginner said:
"James Allen has chosen to use a low gain mic designed for snare drums in a studio environment, so I have to dial-in the gain higher than usual and pick up loads of other things onstage, like the snare drum."
Karl Winkler
    • Lectrosonics
« Reply #13 on: August 09, 2011, 12:18:20 pm »
It helped, thanks!
I heard itīs no good because of its high impedance, what requires more gain and more bleeding into the mic.
IIRC, the 441 is a super-cardioid and has a source impedance of 200 ohms.
Isnīt it too high? For instance the Neumman KMS 105 has only 50 ohms.
Iīm concerned with bleeding on stage due to that high impedance.
Impedance, sensitivity ("gain"), and pickup pattern are all separate issues.
For the impedance issue, many microphones, particularly those with transformers, often have a 200 ohm impedance. That said, some mics with transformers can have 50 ohm impedance as well. Then, more modern, transformerless designs often have 50 ohm or even as low as 10 ohm impedance. All this means is that the electrical source of the microphone has a low internal resistance. As long as you are at least 5:1 with your mic input:source, you're fine. Some people claim that 10:1 is better - I think this is splitting hairs. Since most microphone inputs on mixing consoles and mic preamps are 1K ohms, 1K:200 is 5:1 and you're good to go.
Onto sensitivity or "gain". It is a bit of incorrect thinking that equates sensitivity/gain to the pickup of stage wash. If your gain structure is correct, then you have compensated for any differences in sensitivity between microphone types. True, studio mics often are more sensitive, i.e. they have a "hotter" output for a given acoustic volume level. But again - so you just turn down the gain knob on the preamp.
Pickup pattern has a lot to do with whether or not a mic picks up stage wash: the narrower the patter, generally the more gain before feedback. However, this is also partially dependent on application: for instance, a hypercardioid mic (which has a rear lobe) may not give you the best GBF when you are using a single monitor wedge positioned just behind the microphone.
One of the issues that you don't bring up, though, is the difference between dyanmic mics and condenser mics in terms of their sensitivity to stage wash. Because condenser mics have a low moving mass and thus generally much more linear high frequency response as well as resolution, they tend to pick up more stage wash, despite the pickup pattern. This is a common complaint when using condenser vocal mics like the KMS105: it is easy to hear cymbals in particular. Typically, dynamic mics are a better choice for loud stages as a result.
In theory, theory and practice should be the same. In practice, they are not.
frank kayser
« Reply #14 on: August 09, 2011, 12:23:50 pm »
I've used it for live vocals - outstanding!
The problem was convincing the singer it was not a side address mic :P
Steven Leonard
    • Sands Productions
« Reply #15 on: August 09, 2011, 11:36:20 pm »
Great Post Karl! Right On!
James A. Griffin
« Reply #16 on: August 10, 2011, 11:00:58 pm »
Has anyone used this on vocals?
Great mic for vocals, used it plenty of times in the studio back in the day.   In addition to Stevie Nicks, you'd also see Elton with one on TV all the time.
The mic clip they used back in the 70's and 80's was pretty flimsy... the one used today looks more sturdy... $54.
I need to determine where in this swamp of unbalanced formulas squatteth the Toad of Truth
Keith Broughton
  • Toronto
« Reply #17 on: August 11, 2011, 08:36:50 am »
Quote
Both the 441 and 421 suffered from bad clip design. great mics, terrible clips.  :o
Can't tell you how many times I had to rescue 421s off the toms.
Bob Lee
    • QSC, LLC
« Reply #18 on: August 22, 2011, 06:59:31 pm »
Within the MD441 body is a suspension mechanism that does a nice job of isolating handling vibrations from the mic element, so it's great for hand-held use. I've always hoped to have an opportunity to use one on a vocalist.
Bob Lee
Technical Communications Developer
Application Engineering Team QSC
Fellow, Audio Engineering Society
"If it sounds good, it is good." —Duke Ellington
Karl Winkler
    • Lectrosonics
« Reply #19 on: August 23, 2011, 09:59:04 am »
Quote
I agree - the clips were terrible. The 441 had that complex clip with part clear plastic that inevitably broke. Later (maybe 15 years ago) they made a much more sturdy "soft plastic" clip. Once we had those, we were golden.
When Senn. went from the 421 to the 421 mk. II, I couldn't believe they didn't re-design that clip. Once again, complex and prone to fail. I can't tell you how many times I dropped or nearly dropped a 421 when the clip let go. Seen many of them out there duct taped to the clip so they won't disengage at the wrong moment. Then the worst is when the clip ends up taking a chunk out of the body of the mic.  >:(
ÂŦ Reply #19 on: August 23, 2011, 09:59:04 am Âŧ
Page created in 0.033 seconds with 22 queries.
