Pages: 1 [2] 3  All   Go Down
Author Topic: First Bar Install: Part 1  (Read 12702 times)
Kurt Stephens
Re: First Bar Install: Part 1
« Reply #10 on: January 25, 2011, 07:01:31 PM »
That could be interesting if there ever was any issue.
I'm surprised nobody has asked about the ceiling height and construction, but that would be useful to know.  And speaking of ceiling, are you looking at aspects such as whether you may need to use any plenum or riser rated cabling?
I would address the power issues right away.  It's not clear if there is an Architect involved but somebody is probably coordinating the design and creating construction documents, you want to make sure to coordinate with them as soon as practical.  If you come up with additions or changes late in the process you won't be making any friends and may not get what you want.
Just to reinforce Ivan's point, does your responsibility end when you walk out after installing everything or will you incur some ongoing responsibility and liability?  That may factor into your costs.  And since you want to do this right don't forget about things like labeling all the wires with that labeling reflected on the system drawings that you leave for the Owner.
By the time you account for the costs of not only the main equipment but also of all the associated cabling and cables, connectors, hardware, stands, an equipment rack an so on as well as anything for your effort and liability, will $4,000 cover providing something with which you'd want to be associated?  If you're willing to do this at a loss for the experience and reference or due to your friendship then that is a decision for you to make, but remember that any resulting references may be based on the belief that you could provide similar results for the same cost.  Otherwise, you may want to first consider the more fixed costs and see where that leaves you on the items and work that is more flexible.
I have not looked at cabling ratings. I will add that to my notes.
The bar has already been built quite a while ago. It is simply under his new ownership, but there was no audio of any kind before he got there. I don;t know when the place was built buy I imagine more than 10 years ago. There really won't be many other people to deal with other than hiring an electrician and of course the legal side of things (which is covered by us anyway).
My responsibility will end after I walk out.
Your last paragraph is a great one and it is a serious consideration. Again, given that this is my first install I think I'm going to have to just try to do my best on it. The standards are very very low and ultimately I am not making a living (by any means) doing professional sound installs.
Thanks for your input as well - I rethink over all of this stuff.
Taylor Phillips
« Reply #11 on: January 25, 2011, 10:40:10 PM »
With such a tight budget constraint and the desire for quality you have, I think you should design the system to be added to and expanded easily.  Right now, I think you only need one PA speaker, but you should run cable for a second.  I'd say even run cable for distributed speaker in the farther part of the venue as well.  A couple stage monitors are good to have, but there are a lot of musicians, and the groups like you say would be playing here, who are used to playing without them, especially in small venues.  If you don't get any, still run cable for them.  Another thing to consider, as someone mentioned earlier, is the acoustics of the space.  With jazz ensembles, I think you might want the space to be a bit more live than one that features mostly rock bands.  I don't have enough experience to recommend anything, but I know that different materials will make the space sound better/worse aside from the reverb time.  Anyway, here's a quick list of things to get started with would be (prices from memory):
1 QSC K10 - $700
1 Allen & Heath ZED-12FX mixer - $500
1 Sennheiser e835 3-pack - $250
3 Whirlwind IMP2 DI boxes - $40/each - $120
3 Mic stands - $30/each - $90
10 15' XLR cables for the stage - $15/each - $150
3 2-input XLR wall plates - $15/each - $45
That's close to just $1800 but it doesn't include the power, installed audio cabling, lighting etc. since I don't know much about that.  You might be able to get some package deals on some things, look at B-stock stuff for the pricier gear and get the price lower.  This still may not get you what you want/need.  I put the ZED up there since you're pretty sure that only small ensembles are going to play there, but they may get big, in which case the ZED won't cut it for you.  What you might want to do is install the speaker(s) and cabling and see what kind of acts are booked before you buy the mixer.  I would probably install more than the six stage inputs that I have up there, since that number is just to match the number of mic inputs on the ZED.
Ned Ward
  • Redondo Beach, CA
    • Our band's page on Facebook
« Reply #12 on: January 26, 2011, 01:20:16 AM »
Kurt - thanks for the replies. May come off as gruff, but this topic has been covered to death in the old PSW forms, which you can still google search and will give you a lot of similar responses.
setting up bar PA site:srforums.prosoundweb.com
I do have commercial liability insurance. The plan was made for this type of matter.
Your liability insurance covers you to do installs in a friend's bar, including hanging speakers, lights? What happens (god forbid) if a speaker you hung falls on someone and it wasn't hung correctly? This is serious stuff which is why I recommended walking, especially if you're friends with the guy.
Quote
My family owns a Law firm - I understand this. My Law firm represents him and his bar.
I'm not a lawyer, but this seems like it could get odd and again you don't want your friendship to sour. Since your family is in the legal business, before doing any work, get things in writing so your liability is limited.
Quote
I am not an electrician and would consult those in the know for that matter.
Good reading on this in the PSW as well - have an electrician come in and do that work for you - don't consult and try to do it yourself, because again you open yourself up to liability.
Quote
I do not want anyone here to do my job - I am getting opinions on how other people would approach it and what questions they would ask. Remember this is my first job doing this so go easy. I'm aware that I can and may need to hire someone else.
And that's great; in your original post you're asking for total suggestions and it seemed you were asking for free work; many of the people who haunt these forums are professionals and get paid for that kind of work on installs.
 In the past, PSW forum posts asking for that broad of an answer were smacked down pretty quickly. Read the old forums, do some homework, and then come back with what you think works.
What most people will say is hire an installation contractor and have them at least down to the site to look at and estimate what is truly needed. It may be $150, but having someone who does this for a living tell you how to make it better in person will be way better than forum posters suggesting speakers based off a very rough drawing. That cost may also be refunded or put towards the installation if you go with that person, who may be able to get better than retail pricing and will also buy the right gear for the room.
Quote
I'd like to just throw some ideas around on what might work and what might not - thats the whole basis of a Forum.
Yes, but you need to start by throwing your ideas around first vs. asking for people to do your work for you -- that's the whole basis of this forum.
« Last Edit: January 26, 2011, 01:22:58 AM by Ned Ward »
Brad Weber
  • Marietta, GA
« Reply #13 on: January 26, 2011, 07:35:48 AM »
1 QSC K10 - $700
Those numbers are the equipment prices, but consider that they don't reflect the time spent ordering the equipment, receiving it and storing it until installation, transporting it to the site, installing it or supporting it.  And also no profit for you.  Also, the warranty on items you purchase for which you are not an authorized dealer may be with you and not transferable to the bar Owner, in which case either they get no warranty or you are potentially involved for some time after the installation is complete.
Kurt Stephens
« Reply #14 on: January 26, 2011, 05:27:06 PM »
Thank you for the recommendation - I guess the argument would be that the owner might not like having a partially incomplete PA - and since this is his grand opening he might want to attract attention right off the bat. I will see what his opinion on this is though.
Kurt Stephens
« Reply #15 on: January 26, 2011, 05:33:09 PM »
Thank for the link - I will look into that.
I also appreciate that this forum is very realistic (why I brought issue up here). It would be a disservice to say - "oh yeah this install will be easy for you just get a few x's y's and z's"
I think it is time for me to go back to the drawing board and talk to the owner about some of these issues. I will report back with a Part 2 Thread eventually once I get more specifics. One thing I do have right now is some time to sort through things - since he doesn't need the install completed until May 20 (grand opening).
Kurt Stephens
« Reply #16 on: January 26, 2011, 05:35:43 PM »
The owner's credit card will be used and things will be purchased in his name (thus having the warranty himself). He is also responsible for the upkeep of it.
Ned Ward
  • Redondo Beach, CA
« Reply #17 on: January 26, 2011, 06:39:33 PM »
Other costs that should be considered is acoustic treatment. Especially if jazz or quiet music is planned; spending 1/2 or more of your $4,000 budget on sound treatment could make it sound infinitely better and prevent problems. Again, there's a forum here for sound treatment, but it's also great for consultants to come in, hear the space and hear the problems and then suggest treatment. Since it's a public place, it also needs to be fire-rated, unlike the home stuff.
Brad Weber
  • Marietta, GA
« Reply #18 on: January 28, 2011, 12:29:15 PM »
Unfortunately, the only acoustics forum here is in the R/E/P Section and is focused on studio acoustics rather than live performance venue or large room acoustics.  As you note, when dealing with public assembly spaces versus home studios and with installed systems versus portable systems there are potentially important differences not just technically but also in terms of things that like code compliance and common construction techniques.
Taylor Phillips
« Reply #19 on: January 28, 2011, 05:32:04 PM »
I wouldn't say I was recommending installing an incomplete system; just that because of your budget constraints you should think in phases. Phase 1 can handle a small jazz duo or trio, phase 2 a larger jazz group, phase 3 can handle a full on rock band etc.  I think a lot of places end up with poor systems because they buy more components as time goes by and money comes in, but they didn't have plan from the beginning and everything comes together in a haphazard afterthought kind of way.  I'm saying you should plan the additions now so that doesn't happen.  Planning is a lot cheaper than fixing.
Pages: 1 [2] 3  All   Go Up
Page created in 0.026 seconds with 19 queries.
