Author Topic: I am a DA...  (Read 4578 times)
Louie Warren
  • "Makin' it up as I go along" - Radney Foster
    • Ludietunes
I am a DA...
« on: August 05, 2011, 01:39:32 pm »
In my guitar rig... I am using one of these to connect my pedal board to my racks.  I have a 7 channel and connect 4 to one rack and 3 to another.  It was a major PITA to fish around in the rack to find the connectors.  I decided to make a rack panel so all I had to do is plug them up on the panel and I'm done.   Ordered 7 of these and two of these.  Obviously I was under the false impression that all XLRs were the same size as my old Switchcraft panel mounts...  discovered that D size holes fit the Neutrik NL2 panel mounts perfectly.   So... I ordered 2 of these.
My dumb guitar player questions are:
1. There is no magic washer/jacket/adapter thing to make the connectors I bought fit the D holes?
2. How hard are the pre-punched panels to knock out the specific sizes I need?   Never done one of these before.
Thanx in advance for indulging this old guitar player.
Please help spread the word!
http://www.ludietunes.com/Stolen/
Remember... I'm just a guitar player
Bob Charest
  • Lab Lounge
  • Westbrook ME, USA
    • Bob Charest Band
Re: I am a DA...
« Reply #1 on: August 05, 2011, 01:46:25 pm »
Hi Louie, One of the links you had was to a 5-pin MIDI panel connector - is that what you meant to do?
For anything I've had to do that required holes on sheet metal, I've used Greenlee punches. They've always given me a great result but are expensive. It's a lot harder to get a good result by drilling, at least for me as I don't have a decent drill press. If the panel holes are too big, I don't know of a way to "make up" the difference other than having pre-drilled metal discs that you would have to weld onto the panel.
Best regards,
Bob
TJ (Tom) Cornish
  • St. Paul, MN
Re: I am a DA...
« Reply #2 on: August 05, 2011, 01:52:46 pm »
There's no way to adapt that I know of without a big mess.
Those plates usually come fully punched- it will be all holes with nothing for you to remove.  Middle Atlantic makes one that isn't fully punched out - just the outlines are punched so you can knock out what you need but what you've ordered is already punched.  You can fill in unused jacks with blanks.  http://www.redco.com/shopexd.asp?id=1526
Jim Thorn
  • State College, PA
Re: I am a DA...
« Reply #3 on: August 05, 2011, 10:21:22 pm »
I saw that the diameter of the 5-pin feedthroughs is 0.76", with a flatted side.  Since a Switchcraft D3M panel-mounted MALE XLR fits in a 3/4" hole, I suspect you would be okay if you got a pre-punched panel intended for four Switchcraft D3Ms.  The panels you linked are for FEMALE XLRs, and those take a 15/16" hole, so they're too large.  I'm sorry I don't have a link to the right panel, but I know I have seen them somewhere.
If it were me, I'd buy a couple of 1-space aluminum blank panels (with rolled top and bottom edges for stiffness), and drill my own holes with a stepped single-flute drill bit like the Unibit.  I wouldn't try it with a steel panel, but the aluminum is soft enough to not give you too much of a fight.  If you don't have a Unibit, you should be able to buy one for $25 or less, and it's a great thing to have around for other projects.
Whenever I have had to mount connectors with a flatted side in a round hole, the supplied lock washer has held well enough that I never cared that I didn't have a flatted hole.
I hope this helps a little.
Jim Thorn
Ned Ward
  • Redondo Beach, CA
    • Our band's page on Facebook
Re: I am a DA...
« Reply #4 on: August 05, 2011, 11:06:15 pm »
Since you bought from Redco, give them a call and/or email. I've found them to be very helpful folks.
FYI - they will also (for a price) fill in a rack panel with your choice of jacks with whatever length wire needed on the other side; I was looking at doing it for my 01v Rack.
Other than this issue, how do you like the Pedalsnake? I'm a guitar player as are several on the forum.
duane massey
Re: I am a DA...
« Reply #5 on: August 06, 2011, 02:45:28 am »
Unibit or similar is a great thing to have. I carry 2 sizes, and have had no issues drilling thru aluminum or steel panels, as long as you drill a pilot hole first. Stainless, not so good.
Duane Massey
Houston, Texas
Jordan Wolf
Re: I am a DA...
« Reply #6 on: August 07, 2011, 06:14:25 pm »
+1 for UniBits.  Look for combo packs...you'll get use out them often enough to make it worth it, I promise.
Jordan Wolf
Louie Warren
    • Ludietunes
Re: I am a DA...
« Reply #7 on: August 11, 2011, 11:28:52 am »
Best regards,
Bob
Yes... I need MIDI feed thru connectors.  I have a PedalSnake that uses a 7 channel MIDI snake to go from the pedal board to the racks.
I think I have access to a Greenlee; my old man had one before he died... just have to locate it.
I bought the MidAtlantic universal panels that allow you to punch out what you need.  http://www.parts-express.com/pe/showdetl.cfm?Partnumber=262-575&FTR=universal%201U%20panel    Just need to figure out how to punch them out without screwing things up.
Louie Warren
    • Ludietunes
Re: I am a DA...
« Reply #8 on: August 11, 2011, 11:30:06 am »
Finally figured that out.  Bought two of these: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=262-575&FTR=universal%201U%20panel
Louie Warren
    • Ludietunes
Re: I am a DA...
« Reply #9 on: August 11, 2011, 11:31:47 am »
Jim Thorn
Thanx!
Re: I am a DA...
Page created in 0.1 seconds with 23 queries.
