Author Topic: Bridging Amps to Power Mains  (Read 6848 times)
Brad Weber
  • Marietta, GA
Re: Bridging Amps to Power Mains
« Reply #10 on: August 13, 2011, 06:27:38 PM »
I don't think the venue would ever see using 1500w per box but it would need more than 825w. So I'm stuck with bridging the amps.
The difference between 825W and 1500W is 2.6dB with the theoretical 1m output for an ILS1594 speaker going from 124.2dB to 126.8dB.  Would less difference than that really matter?
Derek Van Winkle
« Reply #11 on: August 13, 2011, 08:45:55 PM »
Very valid point!
Thanks!
Rory Buszka
  • Gearmonger
« Reply #12 on: September 14, 2011, 09:43:00 PM »
Here's another thing to keep in mind: Bridging an amplifier increases the amount of distortion present in its output, because of tiny differences in the output stage of either channel of the amp (even within the same chassis). Distortion in the bass is less audible, so bridging is a better compromise for powering dedicated low-frequency speaker systems. However, amps are less stable in bridged mode than when driving separate loads from each channel, and can't deliver as much current into the load at high drive levels.
It sounds like the clear solution here is to run the amps in stereo.
Friends don't let friends mix a band from the stage.
The expert in anything was once a beginner.
Andre Spur
« Reply #13 on: September 16, 2011, 07:45:32 AM »
Is this a practical thing to do? I've never been a big fan of it, but I just got a project that has already purchased all the amps and enclosures. The only way to effectively power the system is to bridge the amps (Crest CPX 3s) down to 4 ohms and run the enclosures (Peavey ILS 1594s) two per amp.
Any thoughts?
Bridged amps sounds better in dynamics if you do not struggle them with too low impedance loadings :-/
I always prefer bigger (especially in amplifiers) because bigger amp sounds better and has more headroom, later on the limiter the safe range can be fixed.
Some amps are already so big that do not need to bridging like this: http://www.pknc.com/3phase_eng.html
I think this level of power is more than enough even for the biggest speakers.
  • Old enough to know better
  • Audio Plumber
Posting Rules
« Reply #14 on: September 16, 2011, 08:24:37 AM »
Bridged amps
Please go to your profile and change the "Name" field to your real full name as required by the posting rules clearly displayed in the header at the top of the section, and in the Site Rules and Suggestions in the Forum Announcements section, and on the registration page when you registered.
Jean-Pierre Coetzee
  • Gauteng, South Africa
Re: Posting Rules
« Reply #15 on: October 07, 2011, 06:39:02 PM »
Not to hijack the thread but is such an amp even possible, from what I see it's not released yet... Apart from that, 80A on a single phase circuit, good luck getting that without a distro...
Audio Technician
Word & Life Church
- Ivan Beaver
Re: Posting Rules
Page created in 0.036 seconds with 21 queries.
