Author Topic: Yorkville ls608 tuning for Driverack 260‏  (Read 2535 times)
Johnny Culbertson
« on: July 27, 2011, 10:36:45 am »
Does anyone know the crossover, PEQ, etc. tuning for the ls608 subs in the Driverack PA+ Wizard? I have a Driverack 260 and noticed that they are supplied for the Driverack PA+ Wizard, but I do not have access to that unit to see what they are. I'm using the subs with a QSC PLX 3602 and either JBL MP415s or MRX512Ms for tops. Thanks.
« Last Edit: July 27, 2011, 11:03:10 am by Johnny Culbertson »
Josh Billings
Re: Yorkville ls608 tuning for Driverack 260‏
« Reply #1 on: August 02, 2011, 01:13:02 am »
High pass at like 40 hz or so and low pass at 80-100 hz or so with your filter of choice (i use BW24) and call it a night.
You could boost up around 50 hz to "flatten out the response" as im assuming it falls off the lower it goes, but you'll lose output
Josh Billings
Glenn A Williams
« Reply #2 on: August 25, 2011, 12:43:35 am »
I have the frequency response chart for the LS608 and I own four of them.
There is a 3 db dip at 80 hz which tapers from 103 db 1w1m @ 70hz to 100 db 1w1m@ 80hz and goes back to 103 db1w1m @ 90hz.
Page created in 0.078 seconds with 22 queries.
