Author Topic: port tuning  (Read 5479 times)
David Parker
port tuning
« on: July 15, 2011, 03:06:06 pm »
when you calculate the size, number, and length of the ports, do you subtract the volume of the ports from the overall volume of the cabinet?
Ales Dravinec
  • ADRaudio, Slovenia
Re: port tuning
« Reply #1 on: July 15, 2011, 03:36:46 pm »
Absolutely !
w/r
Alan Sledzieski
Re: port tuning
« Reply #2 on: July 16, 2011, 08:42:45 am »
Are you using a program to do this?  Or doing your own math?  What ya building?
David Parker
Re: port tuning
« Reply #3 on: July 16, 2011, 11:21:48 am »
I built four 2-15 subs a few months back, using eminence Kappalite 15 drivers. I used a design on the eminence website, specifically for that driver. They gave the volume of the cab, and the number, size, and length of the ports. It has six 6" ports 11.25 long, to reduce port velocity. I've been well pleased with the performance of the subs, but just got to thinking, those port's volume adds up to about a cubic foot. So I used a port calculator to see how much difference it made in the tuning to deduct the volume of the ports from the volume of the cab, and it's significant. It appears that I can plug one of the ports and pretty much get back to the suggested tuning of the cab without changing the length of the ports, which would be very difficult at this point.
Alan Sledzieski
Re: port tuning
« Reply #4 on: July 16, 2011, 03:12:01 pm »
I use eminence software to build cabinets at time to time, I know changing the port configuration also has a lot to do with how much power the driver will handle at certain frequencies down low.
So what are the changes? By plugging 1 port in responce?
What driver are you using exactly?
I thought they usually give a box design with dimensions??????
Whats your internal box volume?
Did you compensate for the area the speaker takes up in the box?
Plus 6, 6'' ports seems like a lot of area for a dual 15', given the x max and the kinda power they handle they handle.
David Parker
Re: port tuning
« Reply #5 on: July 16, 2011, 05:56:14 pm »
http://www.eminence.com/pdf/Kappalite_3015LF_cab.pdf
Alan Sledzieski
Re: port tuning
« Reply #6 on: July 17, 2011, 10:22:36 am »
When I get a chance I'll plug all the numbers in and see what I get.
 I did look at port velocity graph listed, its very low, they are not running all those ports for reducing port velocity, its for other factors.
Alan Sledzieski
Re: port tuning
« Reply #7 on: July 17, 2011, 12:17:18 pm »
Ok
6 ports   vs    5 ports
 Power handling
40.1 hz, 897w, 900w
39.4 hz, 648w, 900w
38.7 hz, 472w, 900w
38.0 hz, 348w, 900w
37.3 hz, 280w, 756w
34.7 hz, 90.1w, 215w
Port velocity
6 port 10.2 m/s @ 38.7 hz
5 port  12 m/s @ 34.1 hz.
6 port, fb 44, f3 41.01
5 port fb 40.58, f3 41.01
6 port is + 1 db from 133 hz to 70.3 hz over a 5 port.
Conclusion, leave as 6 port, engage the 40 hz low cut on the crossover.  From the way the 6 port handles power I see why they went with the design, simply cutting the frequency below 40 hz, gains a 1db out put in the sweet spot.  Port velocity was never a factor.
Alan Sledzieski
Re: port tuning
« Reply #8 on: July 17, 2011, 12:23:46 pm »
6 port is yellow.  Graph is showing output, you can see the 1 db loss in the 5 port
Gary Weller
Re: port tuning
« Reply #9 on: July 17, 2011, 01:13:44 pm »
What program is that?
Re: port tuning
Page created in 0.034 seconds with 22 queries.
