Author Topic: VRX918SP SPL comparisons  (Read 11362 times)
Kurt Stephens
« on: January 20, 2011, 11:41:16 am »
One of the considerations for my next active sub is the VRX918SP -
what kind of personal experience do you guys have with it? Reliability?
SPL-wise what can you compare it to?
versus the KW181 how big is the difference? How bout the HPR181i?
Would a single one be a good match for a pair of K12's?
Tim Talbot
    • True Sound Hire
Re: VRX918SP SPL comparisons
« Reply #1 on: February 08, 2011, 06:00:17 pm »
Great sub but i would go for two subs rather than just one.... headroom is key :)
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #2 on: March 06, 2011, 08:24:44 pm »
If you can get a real good price for a VRX, maybe it is a good deal but remember that a lot of what you are paying is for the fly rated hardware on it. I have a pair of KW181s with a pair of K12s and am happy.
Kurt Stephens
« Reply #3 on: March 15, 2011, 03:17:43 pm »
Yeah a VRX918SP without the fly hardware would be nice - even still though I am considering it (from back at the beginning of February yes).
I have the funds to buy the VRX - but only if it is the best sub out there under $2000.
Any other options to pair the K12's with? The PRX618S-XLF I've heard overheating problems with and it seems pretty inferior to the VRX in most ways.
Rob Spence
« Reply #4 on: March 20, 2011, 12:17:53 pm »
I did a spreadsheet of powered subs and posted it back in the old forums. I have an updated one.
I tried to include it here but the new forum doesn't take PDFs like the old one did. Fooey!
It is available here
http://www.soundforums.net/live/threads/1008-Powered-speakers-and-subwoofers?p=8088#post8088
« Last Edit: March 20, 2011, 12:35:01 pm by Rob Spence »
Bob Kenton
« Reply #5 on: March 20, 2011, 02:56:09 pm »
Ive used a pair VRX-SP subs a couple of times. Ive never really heard the KW sub other than one single 5 minute setting at GC.
A few quick observations taken from Robs stats.
Dimensions are almost identical, weight is very close with a few pounds less in favor of the KW.
You do get casters on the KW, add another 75.00 bucks for the VRX.
The VRX has a 80hz and a 110hz crossover point. Only in the 80hz setting does the sub have a 80hz high pass out. Set at 110hz the sub output is in full range. Will your tops (K12's) drop down to 80hz? I think the crossover point in the K12's is 100hz. I maybe wrong on that.
Im not sure what is going on in the KW sub, 100hz low pass and full range out?
The KW has L&R inputs and outputs, VRX has one of each. No real issues with that other than its a bit easier to use when a single sub is deployed.
The VRX has a Powercon out which is nice. The KW is quite a bit cheaper too. Ive found the VRX for 1500.00 and less a couple of times and even at that price the KW wins.
Output wise the VRX did fine for my needs when I used them. On paper the KW has more output, would be great if a side by side comparison could be done with these subs.
Kurt Stephens
« Reply #6 on: March 20, 2011, 05:37:02 pm »
Yes I have read your spreadsheet from the old forums but thanks for the reminder. I will have to take a took at the updated one.
Kurt Stephens
« Reply #7 on: March 20, 2011, 05:45:07 pm »
This is really such a hard decision for me. I think every day I change my mind on it - and I've been doing research for this purchase for almost a year!!
Everything you listed I've taken into consideration. The price really isn't my main concern - I have the funds for both - it comes down to deciding which is really the better sub. On one hand I think it is foolish to pay for flyware I'll never use, and extra for casters when the KW already has them - BUT - if it is better performing then it is all worth it. I have heard strong opinions both ways.
Most of the gigs I do are small/medium sized formals/bar gigs but the SPL demand is usually pretty high for the event and I play dance-oriented pre-recorded music. Max real-world SPL is definitely a concern. I don;t trust those paper specs at all - the boundary conditions were different I'm sure. I think the VRX was measured in full-space, and the KW calculated.
I haven't heard the KW at all yet - but have really liked the VRX when I've used it (haven't pushed it though yet).
I can also trade in my K12's and get PRX612M's to better aesthetically match the VRX - and a speaker management system would be nice as well if I go for the VRX.
  • Old enough to know better
  • Audio Plumber
pdf files
« Reply #8 on: March 20, 2011, 08:08:21 pm »
This forum does not allow pdf files for the same reason the old forums did not, they are a common vector for malware. If you found a way to post a pdf on the old forums, it was not directly.
Bob Kenton
« Reply #9 on: March 21, 2011, 01:27:20 am »
Just a quick thought, have you checked out the new Yamaha DSR118? Pretty much the same size as the others your considering.
Page created in 0.052 seconds with 22 queries.
