Author Topic: Wet Speaker Cone...Will it Affect Sound Quality After Drying?  (Read 26237 times)
David Hoover
I searched everywhere and couldn't find an answer to this...
I set up for an event and it got rained out.  A couple of woofers in my mains got wet.  Some of them spotted with drops, one of them a little more wet.  They are all paper cone woofers.  We took the grills off and carefully dried/got the dirt off of them with the edge of a soft towel.  Will this affect the sound quality at all after they are dry?  Will it do anything to the cone?
Bob Leonard
  • Boston, MA USA
Re: Wet Speaker Cone...Will it Affect Sound Quality After Drying?
« Reply #1 on: June 26, 2011, 02:04:28 am »
David,
If the water got into the edge of the cone it may appear to be dry but the edge of the cone will usually tear after about a month. if the edge has been treated to prevent cone cry you may be just fine. If not you could consider a treatment. The treatment material can be purchased from Weber speakers. All you need to do is paint a 1/2" wide area around the cone edge. The sound may actually be better as some of the very high frequencies will be dampened.
BOSTON STRONG........
Proud Vietnam Veteran
David Parker
« Reply #2 on: June 26, 2011, 09:50:21 am »
I've had speakers over the years get spots of water with no ill effects. A soaking is another thing. I've never had one get soaked. Years ago my reconer told me the worst enemy of speaker cones was moisture. I did a lot of outdoor events that went into the night, and commonly my cabs would be soaked with dew when I loaded out, but the cone would be dry, at least they appeared dry. They still lasted a long time. But like I said, I never had a cone get soaked, just sparse drops of rain.
kristianjohnsen
  • Lillehammer, Norway
    • Lillehammer Lyd og Lys
« Reply #3 on: June 26, 2011, 11:43:54 am »
David,
Happened to me as well, they all tore along the transition between diaphragm and dust cap after a few concerts :(
A quick fix/treatment in a pinch (like on tour or when parts are not available) is actually to get the stickiest hair spray you can get on one of those pump-action bottles and have at it!
Randall Hyde
« Reply #4 on: June 26, 2011, 11:51:16 pm »
I once had a pair of JBL Mpro 225 columns sitting in my pickup (with a shell) cones up. It rained. One of the cones filled with water. I had a show the next day. Put a hair dryer on it for about four hours. I've been using that same speaker for four years since then. Now I haven't put that speaker through any kind of analysis to see if it was sonically damaged, but it's held together through some *very* loud shows (in fact, I ran that speaker off an IT8000 last weekend [with DR260 limiters] to test out some used amps I bought).
As far as I'm concerned, I was *very* lucky. I smoked an Mpro 415 LF driver (2033H) last weekend (this was off an XTi 4000, not the IT8000 !!!) and a recone is going to cost $200 or so.
Bottom line is this: try it and see if it works (not at a gig, obviously; or, at least, take a spare with you).
I've had good luck with JBL (one HF driver and one LF driver dead in 7 years), YMMV.
Cheers,
Randy Hyde
P.S. Never leave speakers "cones up" in a vehicle!
David Hoover
« Reply #5 on: June 27, 2011, 08:51:24 am »
David,
Bob,
    On these woofers it does look as if the surround on the edges is coated because it's quite shiny compared to the cone itself.  The cone itself looks untreated.
David Hoover
« Reply #6 on: June 27, 2011, 08:55:30 am »
Cheers,
Randy Hyde
Sweet, it's looking good then for my woofers!!  & I'll remember that advice!
David Hoover
« Reply #7 on: June 27, 2011, 09:02:49 am »
From what it looks like the one speaker cone that got pretty wet might have a change at separating at some point.  So, would you advice just buying a replacement driver and keeping it with me?
Page created in 0.065 seconds with 25 queries.
