EQing help!
<< < (2/3) > >>
Justice C. Bigler:
--- Quote from: Michael Gazdziak on January 19, 2011, 07:04:16 PM ---Also, kick should be on ch 1, not 17, snare should be on 2, you need to add hat on ch 3, and toms should be on 4. Also, you need to have 2 kick mics, 2 snare mics, and it doesn't matter if the kit has been tuned.
--- End quote ---
Says who? I pretty much never have the kick on channel one. In fact I rarely have ANYthing on channel one. I keep my inputs patched closer to the center of the console so I have to stretch less to reach them.
Also, I always patch so that the vocals (or violin 1 if no vocals) are on the first faders, from there I go in score order--strings, woodwinds, brass, piano, percussion and odd inputs like video, or playback at the bottom of the input list. I will also many times leave an empty spacer channel between groups of inputs.
There's nothing special about putting the kick drum on the first channel.
Dave Bigelow:
I have to agree with Justice there when it comes to you and only you mixing, put it where you want. If it makes sense to you and no poor bastard has to come in and decipher it who cares?
Now when I send an input list that shows kick 1 on 1, kick 2 on 2, snare top on 3, snare bottom on 4, etc I expect to see that. If not the changeover is gonna take a few minutes longer while we both get up there and re-patch.
Clayton Luckie:
--- Quote from: Justice C. Bigler on January 20, 2011, 02:02:35 AM ---Says who? I pretty much never have the kick on channel one. In fact I rarely have ANYthing on channel one. I keep my inputs patched closer to the center of the console so I have to stretch less to reach them.
--- End quote ---
You probably couldn't see Mike's tongue in his cheek from where you were sitting.  Besides, everyone knows that ch1 is where you put the Tesla Coil.
cl
John Halliburton:
A few things:
Make sure the drums are in good shape, fresh heads, and TUNED properly.
What mic are you using on the kick drum?
Zero out that eq first.
Work on mic placement, get that sound as good as you can get it, then go back to the eq.
As others have said, use your ears, not the display.
Experiment, and not one hour before the gig during soundcheck if at all possible.
Best regards,
John
Andre Vare:
--- Quote from: John Halliburton on January 20, 2011, 10:20:26 AM ---What mic are you using on the kick drum?
--- End quote ---
No!  :o
Andre
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
