Author Topic: Crown VZ5002 vs. QSC PL380  (Read 8223 times)
john sanders
  • Eastern Long Island, N.Y.
    • Sonimax Light & Sound
« on: June 04, 2011, 06:58:38 pm »
I've recently upgraded my foh boxes from (4) EV QRX115's to (4) EV QRX212's. Prior to this change (1) Crown VZ5002 powered all 4 boxes @ 4 ohms/side. With the changeover the 212's would present a 2 ohm load per side; not good for headroom etc..
Here's my quandry: purchase another very heavy VZ5002 or sell the VZ5002 and purchase (2) QSC PL380's. I'm hoping your suggestions can help with this.
Drew Curtis
Re: Crown VZ5002 vs. QSC PL380
« Reply #1 on: June 04, 2011, 08:00:06 pm »
I think you have the right idea.
Blake Courtney
« Reply #2 on: June 04, 2011, 08:55:35 pm »
Depending on how hard you push your boxes I think you would be fine with the 2 ohm load. I run 4 qrx212's off of PLX3602 AND a plx1804, bi-amped. Did that today for 7 hours straight outdoors. No problems. Now, when I need the extra headroom I add another 3602 and only run a pair per amp.
One thing to keep in mind is that the PLX and prob the PL will need a good amount of current at two ohms.
Either way you will love the weight savings.
Blake
Jeffrey Knorr - CobraSound.com
    • CobraSound.com
« Reply #3 on: June 05, 2011, 02:12:00 pm »
Hi John,
I would start by trying the rig as is.  The MA-5002's were Crown's top of the line of the day and were designed to power 2 Ohm loads all night.  If everything works well, which I think it would, you should be fine without adding a second amp.
We have a rack of PL380's and they have been very solid for us.  With that said, I wouldn't think that they would have much more output watt for watt vs the 5002's.  The PL380's will however off lighter weight and reduced power draw (the benefits of Class D amplifiers).
Jeff
Franz Francis
« Reply #4 on: June 07, 2011, 03:49:00 pm »
Also switching to the P380 might leave you starving for the MA-5000's harmonic distortion, it’s less apparent in the QSC 380.
Franz
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #5 on: June 07, 2011, 11:15:02 pm »
Blake
I use a pair of PLX3402s and one PLX1602 to biamp my pair of QRX212s. Perfect match I think.
Drew Curtis
« Reply #6 on: June 08, 2011, 11:44:57 pm »
The only problem with running a single 5002vz to four boxes is that each box is only seeing about 1250 watts potential power (4 to 2 ohm load doesnt get much more out of this amp, see specs attached)
2 pl380s would add power to the 2000 watts each box is currently seeing (2500 watts stereo @4ohms) instead of nearly cutting it in half.
Edit: Yes, the specs are at 1k, but its a good reference as both manufacturers are printing specs as such
« Last Edit: June 08, 2011, 11:47:03 pm by Drew Curtis »
Vinny DAgostino
  • Warwick, RI
« Reply #7 on: June 09, 2011, 01:31:01 pm »
I don't see a problem, the QRX212 is only 600w @ 4ohms continuous.
    • CobraSound.com
« Reply #8 on: June 09, 2011, 11:14:10 pm »
+1
Drew Curtis
« Reply #9 on: June 10, 2011, 11:03:05 am »
totally, I was thinking they were 1200 watt boxes for some reason. I was probably thinking of the srx722 as theyre in the same league. I'll agree then and say the macro will handle it.
Page created in 0.055 seconds with 24 queries.
