Author Topic: c  (Read 4729 times)
Goerge Thomas
c
« on: May 21, 2011, 04:04:04 am »
c
« Last Edit: February 08, 2012, 01:34:36 am by Patrick Beaugrand »
Mike Diack
  • Auckland, New Zealand.
Re: About JBL MP418Sp failures
« Reply #1 on: May 21, 2011, 09:32:46 pm »
Have a single JBL MP418SP that has its crown amp take a dump and blow up the driver in the process. The unit had no signal at the time. The fuse did not blow. The driver caught fire and the amp module now has a solid Clip light and blinking fault. Fault is blinking for channel 2.
I know this has been a long running issue..
I will recone the driver.
The amp module is where I have questions of what to do with it. What do you think happened and how can it be repaired?
This is SOP for these amps. They are useful for mooring a modestly sized dinghy.
When I rebuild these I replace all the SMD emitter resistors with standard WW types (and of course replace all the blown semis). Also remove the triac crowbar circuit (Crown did this in the later ones).
Often the arcing in the blowup destroys the speaker relay as well. So far none of my rebuilds have bounced (touch wood).
M
Goerge Thomas
c
« Reply #2 on: May 22, 2011, 09:28:49 pm »
c
« Last Edit: February 08, 2012, 01:34:50 am by Patrick Beaugrand »
Mike Diack
« Reply #3 on: May 23, 2011, 06:05:03 am »
what cost am I looking at here do you think? for something you would do...I know its a true piece, but it works well enough when it worked I would like to save it if the costs are not too high. I could ship if off to you for not too much I am sure.
Best you find a competent local tech to fix it - these things are well documented (I'm in the wrong country anyway).
M
Goerge Thomas
c
« Reply #4 on: May 23, 2011, 09:58:33 am »
c
« Last Edit: February 08, 2012, 01:34:58 am by Patrick Beaugrand »
thanks for the help!
Anyone in columbus/cincinnati/dayton/northern kentucky area willing to work on this?
I called a few placed but they say oh...we charge $100 to diagnose and $90 after that...
That gets expensive fast if they dont know what they are doing specifically.
The fees quoted are not out of line these days.  Did you contact JBL directly?
Goerge Thomas
c
« Reply #6 on: May 23, 2011, 06:21:48 pm »
c
« Last Edit: February 08, 2012, 01:35:06 am by Patrick Beaugrand »
Yes, the rep I got said that it was NOT common and that they are sorry for my problems. The cost would be between $250 base rate to -$450 it sounds like. The rep was not helpful at all.
I suppose how one defines "helpful" enters into it....
Have fun, good luck.
Tim Mc
Micky Basiliere
Call Crown direct... JBL has nothing to do with the repair of these amps.
Tim Mc
Goerge Thomas
c
« Reply #9 on: May 23, 2011, 10:58:55 pm »
c
« Last Edit: February 08, 2012, 01:35:16 am by Patrick Beaugrand »
c
