Author Topic: Martin 518 Tilt Function No Control  (Read 2458 times)
Bill Bluell
« on: May 11, 2011, 04:58:41 pm »
I have a Martin 518 Pro that when run in standalone mode functions completely. When connected to a dmx controller however, I lose control of the tilt motor. All other addresses in the fixture function 100%. The tilt motor does not seem to be energized at all. I have switched out motors with no impact and since it works in standalone mode, I know it is not an issue with the motor itself. Has anyone had this problem and do you know how to correct it. Thanks, Bill
James Feenstra
Re: Martin 518 Tilt Function No Control
« Reply #1 on: May 11, 2011, 07:05:47 pm »
What controller are you running it off of? You may have a bad profile for the fixture...
Have you tried changing the address?
It may also have a bad receiver chip, but I'd think it's more a software issue than hardware given the fact that standalone functions properly. Does it work in master/slave mode when slaved to another fixture? This uses the same control pathing as dmx does so would be able to indicate a hardware fault
Elevation Audiovisual
www.elevationav.com
Taking your events to the next level
Darren Scaresbrook
  • Adelaide, South Australia
    • Concert Systems Australia
« Reply #2 on: May 12, 2011, 03:11:11 am »
The 518 has 3 modes it can be run in. These are selected internally with a jumper. Make sure your fixture profile matches. ie: 8/16 bit etc.
The dip switches on these are a common fault also, I replaced 4 last week! Are the other functions showing up on the correct channels or are they offset? If so, this could indicate the dip switch.
Darren
Bill Bluell
« Reply #3 on: May 12, 2011, 03:52:09 pm »
Darren
Will wonders never cease. I omitted that I had run the scanner in master and then in slave with another scanner. I also took the board out and checked for bad solder joints. Not an extremely difficult task but one you don't want to have to do again.
Then I read the post by Darren. The sad part about his post is, I could hear it in his voice when he was writing the post saying " Idiot, check the mode first". That's exactly what I did after toiling over the other options I tried and wallah..... The jumpers were open on the other scanners and set to a different mode on the added scanner. The funny thing is and a reason I never thought of it is....are you ready for this... sadly, I am an idiot  :-[.
Thanks to Darren and James for the help. Next time I need to be reminded of what I am doing wrong, I'll just pm you guys first. Thanks again for the help, Bill
Page created in 0.035 seconds with 24 queries.
