Church and H.O.W. Forums for HOW Sound and AV - Your Displayed Name Must Be Your Real Full Name To Post In The Church and HOW Forums > Church Sound Archive
sermons on cd are too quiet
<< < (2/7) > >>
Shad Hall:
Dick Rees wrote on Fri, 06 August 2010 17:11
Shad....
Go out and get yourself an EbTech "Line Level Shifter" and place it between the outputs of your board and the CD burner.  You are getting a -10 "consumer level" output and the burner is looking for a +4 "pro level" input signal.  I have this same issue with my Tascam burner and boosting the signal with the level shifter allow me to actually have the use of the input control on the burner.
As a bonus feature you will also tranformer isolate the two units which can be a good safeguard against any hum, buzz or other noise on the recording.
DR
hi dick,
thanks for the helpful reply. i'll try to get it purchased this week.
just to make sure i got this right, is this how you would suggest hooking up the line level shifter?
mixer "tape out" {rca's} > line lvl shifter -10 dBV {1/4 ts} > line lvl shifter +4dBu {1/4 ts} > tascam "line input" {rca}
thanks
Dick Rees:
Shad Hall wrote on Fri, 06 August 2010 20:36
Shad....
DR
hi dick,
thanks
Shad...
That's how I do it. Here's a link if you haven't already done the "Google".
http://www.sweetwater.com/store/detail/LLS2
DR
George S Dougherty:
If you don't already have compression on the pastor's mic or inserted on the outputs, it's a good idea to do that too.  Something like an RNC in Super Nice mode would work well.  Only bugger there is Super Nice isn't an option that sticks.  It resets each time the unit looses power.  Even the normal compression does well though.  It'd be my first choice as a simple compact stereo unit with plenty of control.
Arnold B. Krueger:
Dick Rees wrote on Sat, 07 August 2010 01:11
Shad....
I've never seen an audio CD player that didn't have enough gain reserve (about 11 dB are needed) to overcome this situation.
Once you apply the recommended linear audio gain by external means, you still have done *nothing* to address the problem. All you will have done is had to readjust the gain control on the CD recorder to accomodate the higher input signal. You'll still be making recordings where the sermon is subjectively (and actually) about 10 dB quieter than the music.
The core of the problem is that there is a difference between live listening and listening to recordings, such that there is this need to add about 10 dB to the spoken word parts to make them seem to have the same loudness as the music on the recording. I've talked to a ton of church volunteers about this and we all see it.
The suggestion that a compressor be used to automatically make up the difference is one potential solution.
Another solution is to simply manually advance the gain on the recorder just before the sermon and announcements start, and back it down before the music starts. You can put 2 marks on the front panel, one for music and one for spoken word.
Or, you can edit the CD before you distribute it and make up the difference in the digital domain.
Dick Rees:
Arnold B. Krueger wrote on Mon, 09 August 2010 06:34
Hi, Arnold.....
I quote the above in reference to the OP stating:
"input volume on tascam is maxed out."
This tells me that there is no way to "manually advance the gain on the recorder" as you recommend.  By simply showing the recorder a stronger signal you can now use the tecnique you recommend.
In several church installs I've done I have used a Rane "Swiss Army" line distro to address the issue of needing different levels of the same feed for recording, crying room, fellowship hall, etc.   This is another (more expensive) fix.
Whatever works.  I just was stating the way that I do it when the house is being fed a signal at +4 and the tape outs are at -10.  The little level shifter box simply puts them both at the same level.
Best wishes.
DR
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
