Author Topic: Longer cable 15 Amp Edison to Left-angled IEC connecter than 15 ft?  (Read 2535 times)
Ned Ward
  • Redondo Beach, CA
    • Our band's page on Facebook
Looking to build a 25' power/audio snake for my pedalboard. I have the VoodooLab Pedal Power 2, and would like a left-angle IEC connector to have the cable exit on the left side of the power unit and the pedalboard.
So far I've found a 15' length 14 gauge version here:
http://www.stayonline.com/detail.aspx?ID=10289
This would only ever be used to power a guitar pedalboard, and would be connected to a well-shielded 1/4" instrument cable to simplify setup. Ideally I'd want 20-25 feet total.
Is 15' the max length for an IEC cord, or does anyone know of longer lengths with that left-angled IEC connector?
Thanks.
Steve Hurt
  • Lab Lounge
Re: Longer cable 15 Amp Edison to Left-angled IEC connecter than 15 ft?
« Reply #1 on: April 22, 2011, 01:21:12 am »
Thanks.
I have 25' straight IEC cables and have seen 50'
You can make your own by the way.
http://www.stayonline.com/iec320-connectors.aspx
Ned Ward
  • Redondo Beach, CA
« Reply #2 on: April 25, 2011, 12:10:25 am »
Thanks steve - I have straight 25' which works. To have the cable exit the power unit closest to the edge of the pedalboard, it needs to be a left angle IEC - the opposite of the one in the connector page you sent.
I'll probablly just use straight and be done with it, as 15' won't cut it.
Tim Padrick
  • Indianapolis
    • T.P. Audio
« Reply #3 on: April 25, 2011, 01:29:52 am »
If you can live without the right angle, get them here: http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10228&cs_id=1022801
If you want to make your own: http://www.galco.com/scripts/cgiip.exe/WA/WCat/itemdtl.htm?pnum=320IEC15-MRCO&source=AdWords&gclid=CNa-qIGl-6MCFdj75wodXzBNJA
I prefer to use PowerCons whenever possible.  Of course you can't just run to the local appliance store and get one if your cable gets lost or buggered.
Ned Ward
  • Redondo Beach, CA
« Reply #4 on: April 25, 2011, 10:41:18 am »
thanks Tim. Since this Edison-IEC will be made into a custom snake for a guitar pedalboard, and I'm the occasional amateur sound guy, I dont have any PowerCon gear, but do appreciate the connector and its benefits.
I'll be able to live with the power cable exiting the front of the pedalboard and making a 90 left turn before joining its audio cable in a snake for 25'.
Page created in 0.085 seconds with 22 queries.
