Author Topic: QSC KSub - Dual 12" 1000 Watt Active Subwoofer  (Read 8790 times)
Brad Weber
Re: QSC KSub - Dual 12" 1000 Watt Active Subwoofer
« Reply #10 on: June 28, 2010, 12:09:18 pm »
Tim Padrick wrote on Sun, 27 June 2010 20:01
I disagree.  Case in point: In one club at which we play regularly, our stacks (including subs) have to set about 4 1/2' from the side walls (owing to the DJ system).  Usually I cut a bit of 60Hz from the subs, but here, owing to boundary cancellation, not only do I not need the cut, EQ at 60Hz makes very little discernable difference.  http://www.padrick.net/LiveSound/CancellationMode.htm
I'm not sure what you are disagreeing with.  The discussion was about boundary or space loading where the concept is that the source is close enough to the boundary to have coherent summation of the direct and reflected sound at all locations and for all frequencies of interest.  You seem to be discussing almost the opposite, where the path length difference from a reflection is sufficient that it does affect the response within the frequencies of interest.
The interaction of the direct and reflected signals is based on the path length difference between the two signals at the receiver (listeners).  If the difference is one half wavelength then destructive interference or cancellation occurs, if it is one quarter wavelength or less then some level of constructive interference or summation occurs and if there is no difference (both signals in phase) then there is full summation.  The idea of boundary loading is that the source is physically at the boundary, thus any reflection has no path length difference from the direct sound and sums for all frequencies.  The same applies to a receiver, if the receiver is located at the boundary then that also causes the reflections from that boundary to be coherent with the direct sound.  So whether the source or receiver is at the boundary, you get the same resulting summation, but only for one or the other.
It gets more complicated when the source is close to but not at a boundary.  In that case you have to look at the relative paths for the direct and reflected sound and how those relate to the wavelengths of the frequencies of interest.  With subwoofers you have a limited frequency of interest and one that relates to longer wavelengths.
If a listener was at the subwoofer then any boundary interaction would be be based solely on the distance from the subwoofer to the boundary.  However, the listeners are not usually at the subwoofers, thus you have to consider the path length differences for the listeners.  Look closer at the typical floor boundary or 'floor bounce' condition and you will find that for a subwoofer one usually does not have to be that far from the sub for the resulting path length difference between the direct and reflected sound to be less than one quarter wavelength. Basically, even though their ears are not at the floor, the listener does not have to be that far from the sub to start sharing the effects of the floor boundary.  But that does not necessarily hold true for more distant surfaces, those may create reflections with a much greater path length difference, or for higher frequencies with much smaller wavelengths.
Brad Weber
muse Audio Video
www.museav.com
Darin Brunet
« Reply #11 on: June 28, 2010, 01:41:49 pm »
Russ Buck wrote on Tue, 15 June 2010 12:09
Still trying to figure out speakers for my church.  My latest idea is to find some decent mains to fly and then a powered sub.  Was wondering if anyone has anything to say about these powered subs?
I have used the QSC K-10 and K-12 self-powered speakers and think they represent a good value and sound quality. The KSub is a bandpass design and many feel this design style as one-noted or boomy. I wholeheartedly disagree with this mentality.
In many instances they are less able to be localized due to the acoustic filtering of harmonic distortion products that cannot be reduced with a crossover, whether passive or active, and it cannot be EQ'd out. On the other hand, a poorly designed bandpass can suffer port compression heard as "chuffing" or air turbulence caused by the air passing over sharp/un-radiused edges (also a problem with poorly designed reflex systems). I have designed many bandpass systems that are very musical and play to very high levels.
Point is, there are terrible products out on the market that utilize many different design styles, whether bandpass, reflex, sealed or TL. I cannot dissuade anyone from using any particular design as long as the design compromises are understood and dealt with.
If used properly, I think the KSub is a quality unit and will serve you well. Perhaps several of them will be required to meet your output needs.
"Serve God first, everything else falls into place"
Darin Brunet
« Reply #12 on: June 28, 2010, 01:52:00 pm »
Jim Ogann wrote on Tue, 22 June 2010 22:45
Powered Subs are good. They usually have the crossover installed as well. Parts Express sells a lot of them. We use an EV S-18 and a 500watt amp (half of a stereo amp) and crossover and rattle the walls in a 600 seat room. Two keys we have learned. 1. Get a crossover with a high pass filter and turn it on.   2. Fly the sub as well. When we flew our sub it made it 100 times better.
You could get a JBL JRX118SP Powered 18" from Parts Express for $750 (Sku 245-818) and be done. It has the amp, crossover etc. Just plug and play - - but fly it up there with your mains and you will really love it.
Perhaps you mean the JBL VRX918SP self-powered sub. The JRX118SP is not meant for flying.
Page created in 0.042 seconds with 23 queries.
