Church and H.O.W. Forums for HOW Sound and AV - Your Displayed Name Must Be Your Real Full Name To Post In The Church and HOW Forums > H.O.W. AV Archive
Controlling house lights with DMX
<< < (2/2)
Yohann Park:
From all the research that I have done, I found only one that might fit my needs.  The issue is the type of input requirements. I want to be able to use the current dimmer feeds for the power. That would be 120v 20A single phase.  The only architectural dimmer I found that meets these requirements is the Lightronics at-402.  This dimmer will take single phase 20A input per channel and output four channels at 2400W.  I was wondering if there were any other companies that had any other similar offerings. What I am not completely sure of is how I will have a remote station that will work with the dimmer console.  I thought that you could only have one controller per DMX universe..Please correct me if I am wrong.
Christy L Manoppo (okky):
no... the remote controller will only controls the AT-402 dimmer. When a DMX signal is present, the remote will be locked out to prevent changes by an unknown person (children, for instance).
Yohann Park:
From what I have read, the wall switch is a momentary contact switch (that is hard wired to the AT-402) that will turn the lights only full on/off? Correct me if I am wrong. So if I turned on the house lights with the remote switch and then walked over to the console, the console would override the remote switch?
yes. It will block all comm from the switch. So the lights console will became the main controller.
Yohann Park:
What is your opinion on the Leprecon VX-2400 series one dimmer with 12 channels @2400W?  I have one currently and was wondering if I should get a newer dimmer since this one is about 10 years old.
Navigation
[0] Message Index
[*] Previous page
Go to full version
