Gene -
DMX will need to be run in a sequence - in one dimmer, out of that dimmer to the next, etc and then terminated at the end to prevent echos. The only way to run a DMX "tree", like I think you have done - one main trunk from console to many branches - is to use an optical splitter. The splitter will have one input and multiple outputs. Each output should be terminated at the end of its run. Termination may not affect you at all unless you are adding intelligent lights. Most dimmers will not be messed up by an unterminated line.
In my opinion, cheap dimmers are a poor investment. Most $200 dimmers will be replaced every 1-2 years. Spending 2-4 times that will get a better product that will last for a decade or two and handle much higher loads. I work with a couple of companies that have and still use Leprecon tree and rack-mount dimmers that were made in the 1980's and 90's.
As always, my advice is worth exactly you paid for it,
Mark
