Author Topic: Video Feed Over Fiber  (Read 2458 times)
Kristian Stevenson
« on: December 24, 2008, 12:18:52 pm »
I was wondering if there was a product out there that converts composite video and mono audio to go over fiber. I found the kramer 611T & 611R but they only have one channel. We are planning a video feed run of about 300ft from our sound board to our youth room to use as overflow. I thought about coax and boosters but I figured fiber would yield better quality.
Brian Kent Tennyson
    • http://www.visitec.com
Re: Video Feed Over Fiber
« Reply #1 on: December 24, 2008, 12:24:01 pm »
I would look at video over UTP cable (Cat-5) much cheaper and you can find plenty of transmitters that will do 300'
You can't get enough, but enough ain't the test.
Brian Kent Tennyson
Visitec Inc.
www.visitec.com
Kristian Stevenson
« Reply #2 on: February 04, 2009, 02:21:57 pm »
the signal from these CAT5 adapters cannot travel through network hubs can they?? If they could, it would make my life A LOT simpler.
Karl P(eterson)
« Reply #3 on: February 04, 2009, 02:29:08 pm »
You can get that technology, but not only is it relatively expensive, but it also brings up latency questions of its own. Furthermore, unless you are sending uncompressed SDI ($$$$$$$$$$$) you will also have compression and codec artifacts to contend with.
Sometimes this is still the right answer, but not when cable is even remotely possible to run.
Karl P
Audio Team Leader - CCH
Kristian Stevenson
« Reply #4 on: February 04, 2009, 08:59:11 pm »
ohok, i didnt even know that it could be done. I guess we'll jus have to spend a saterday and run a new cable. I was looking at the kramer 711N and 712N adapters.
Page created in 0.083 seconds with 24 queries.
