Aaron is right, it sounds like you're simply overcompressing. I use compression on my E6s and Microsets to help sustain a more consistent level for voices, especially the pastor who can go from an intimate whisper to commanding yell, but it only needs to top off the peaks.
Mine is set at a moderate 4:1 or 5:1 ratio setting, and a soft knee setting if you have it. I would then adjust any compressor input and output levels to unity so that with the compressor temporarily set at a 1:1 ratio, you will hear no change in level when you BYPASS the compressor (OUT on units labeled In/Out).
Then with the Ratio reset and the compressor cut IN, you can lower the Threshold setting from the Unity ("0") point until you see the gain reduction meter start compressing the louder levels to a point you desire. This all will avoid loss of level or the compressor squashing the lower levels causing you to increase mic levels and cause the feedback.
Hope this makes sense and helps.
