Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > Pro AV Forum
OMNIBUS AVB Support
(1/1)
Eddie Pitman:
Hi all,
Eddie here from Audiomovers.
We have recently released an update to our routing tool OMNIBUS which now includes network audio support via AVB and NDI protocols as well as various other new features.
AVB in OMNIBUS allows you to connect multiple Macs together via AVB enabled ethernet adapters. You can share up to 256 channels IO and only one machine needs OMNIBUS to create these AVB devices. These devices will appear as core audio devices on any Mac connected to the OMNIBUS host via AVB enabled ethernet adapters/ports.
If you have a minute I've attached a video link walking through OMNIBUS AVB support. https://www.youtube.com/watch?v=s4cYKJwx6Oc
There's a 7-day demo you can get on our website and you can check OMNIBUS out here https://audiomovers.com/omnibus/
Cheers,
Eddie
Scott Holtzman:
--- Quote from: eddie@audiomovers on July 30, 2024, 05:05:03 AM ---Hi all,
Cheers,
Eddie
--- End quote ---
That's great but you need to learn to read instructions.  You must use your real name or follow the vendoe registration process.  This is clearly labeled when you sign up.
If you don't fix your display name a mod will see it and lock you out of posting until repaired.
Thanks for your cooperation.
Scott
Navigation
[0] Message Index
Go to full version
