Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > LAB: The Classic Live Audio Board
Battery powered CM Lodestar
(1/2) > >>
Bob Faulkner:
CM has come out with a battery powered Lodestar lift ("BatteryStar").
https://www.cmco.com/en-us/products/hoisting-lifting-equipment/battery-hoist/
https://www.youtube.com/watch?v=ntFdHPUsFII
Looks like it has a weight capacity of 1000kg (2200 lbs).  Uses a large-capacity Milwaukee M18 battery!
There's been a few times I would have rather had a chain lift vs the tower-lifts I have.  The tower lifts can be a pain to setup, but they do work excellent.  A chain-motor lift would have been a much quicker deployment.
Anyway, looks like a good solution for maybe us smaller shops.
Tim McCulloch:
--- Quote from: Bob Faulkner on June 10, 2024, 10:30:28 AM ---CM has come out with a battery powered Lodestar lift ("BatteryStar").
--- End quote ---
This got some discussion over at ControlBooth.com a couple weeks ago.  Most didn't see any advantage in a venue/show situation, but there is some utility if you need to unstack loaded cases without a fork lift, etc.
Take a look at the price.
Riley Casey:
Short of a sky hook how does a battery motor change the equation against a tower lift? Electricity is fairly easy to come by compared to creating a thing 20+ feet in the air to hang a motor & its load.
--- Quote from: Bob Faulkner on June 10, 2024, 10:30:28 AM ---...
--- End quote ---
Bob Faulkner:
--- Quote from: Riley Casey on June 10, 2024, 01:14:40 PM ---Short of a sky hook how does a battery motor change the equation against a tower lift? Electricity is fairly easy to come by compared to creating a thing 20+ feet in the air to hang a motor & its load.
--- End quote ---
Forgot to mention, my lifts have a manual hoist.  There's a lot of turning on the crank.
Caleb Dueck:
--- End quote ---
I can see a use in the install world - structure but no power, and plenty of Milwaukee batteries around.  Lifting subwoofers and larger speaker up to structure.
Navigation
[0] Message Index
[#] Next page
Go to full version
