Author Topic: Connecting amplifiers and crossovers to Presonus studiolive 32sc  (Read 371 times)
Ionescu Florin Gabriel
Hi all!
 I have a question.
How do I connect together 4 amplifiers, 2 two-channel amplifiers, and 2 four-channel amplifiers and a db Mark DP48 plus crossover, on the Presonus studiolive 32sc and what settings do I need to make to have separate channels on both subwoofers and tops to be able to make corrections separately from eq?
Re: Connecting amplifiers and crossovers to Presonus studiolive 32sc
« Reply #1 on: June 01, 2024, 08:51:28 PM »
Hi all!
 I have a question.
Wow we will help you but that's a big job.  You need to ask more specific questions.  Personally I would hire a local engineer to set it up for you.  If you have all the cabling, network switches, panels etc. it's baout  a 2 or 3 hour job.  If you are missing parts it's a rabbit hole.
« Reply #2 on: June 03, 2024, 10:22:55 AM »
Hi all!
 I have a question.
You hook the outputs to the inputs as needed for YOUR particular situation.
Without knowing YOUR specific situation/goals/gear, there are any number of different ways to hook it up.
And even more different ways to adjust and operate it.
Mike Caldwell
  • Covington, Ohio
« Reply #3 on: June 03, 2024, 08:06:52 PM »
Not picking on Ionescu but I have a had conversations with some friends about how the upcoming generation of sound people will have no real idea how to put together a system other than mixer output to speaker input.
Yes it's outputs to inputs, the configuration of the DSP for the routing and even a basic crossover function is where things will get tricky.
Maybe find someone who has done system set up and can work their way around a DSP for a little help.
What are your speakers, that will make a BIG difference on the DSP configuration.
