Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > AC Power and Grounding
ID this connector?
<< < (2/3) > >>
Brian Jojade:
--- Quote from: Chris Hindle on March 22, 2024, 08:43:45 AM ---Over 600 USD$ for ONE plug?
OK, it's a Hubble, but really?
Guess I need more, better customers to afford to add that to my Tye-In kit.....
Chris.
--- End quote ---
When you need a waterproof connection, that what it costs.  And government LOVES to use those.  Different than the OP's connector though.
Brian Jojade:
https://www.mroglobalsolutions.com/products/appleton-acr3044-600vac-30a-nsnp
Found it.
Wait, that was the 30 amp version.
Here's the 60 amp one.
https://www.amazon.com/Appleton-ACP6034BC-Metallic-Clamping-Ring/dp/B007QQSF4E
Peter Kowalczyk:
--- Quote from: Brian Jojade on March 23, 2024, 01:29:44 AM ---https://www.mroglobalsolutions.com/products/appleton-acr3044-600vac-30a-nsnp
Found it.
--- End quote ---
Thanks.  Seems pretty esoteric.  The facilities manager at the location said they'd never used them and didn't have any kind of breakout box to go with.  Sigh...
Mark McFarlane:
--- Quote from: Peter Kowalczyk on March 26, 2024, 03:20:45 AM ---Thanks.  Seems pretty esoteric.  The facilities manager at the location said they'd never used them and didn't have any kind of breakout box to go with.  Sigh...
--- End quote ---
I'd want to get multi-meter on this outlet, if you want to use it, before buying or building a bistro :).  If it's never been used it may not be live.
Brian Jojade:
--- Quote from: Mark McFarlane on March 26, 2024, 06:03:33 AM ---
--- End quote ---
ALWAYS meter new plugs, especially non standard ones.  You would be surprised how often even regularly used plugs are miswired.  It isn't often an issue when using just one, but when you use multiples in different areas things can go poof quickly.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
