Church and H.O.W. Forums for HOW Sound and AV - Your Displayed Name Must Be Your Real Full Name To Post In The Church and HOW Forums > Church Sound
Baptismal micing techniques
<< < (2/4) > >>
Matthias McCready:
Crown PCC-160's can be a cool unobtrusive mic if you have a flat surface within proximity, they sound great, I believe the gent who designed them branched out on his own and they are not terribly expensive (I am however forgetting the name of the designer and company off the top of my head).
For in the water, a wireless bodypack in a condom in an arm band on the non-dunking shoulder can do the trick, I probably would not use a nice headset though, use something cheap or I do see "waterproof" models exist, I am not sure about the claim, but could be worth a shot.
PS: Buying a pack of extra-large condoms with the church budget is always fun, especially when someone from finance does not know what they are for.  ;D
For my last round of baptisms I put a HH on a stand next to the pool, which the pastor used from the pool a few times, without dropping it in or getting it wet - he stuck to my bargain with him.  ;D
I have a sibling who lives in a small city in Central America, and a pastor at a local church using a wired mic for baptisms when they accidentally dropped it in the water; unfortunately, that was the end of that sound system and the pastor's life - I am assuming there was some other power stuff going on and that something wasn't grounded/wired properly, but I still like to give water and wired stuff a wide berth all the same!
Erik Jerde:
It's largely gonna depend on the style of baptism that your pastor does.  The last time I got in deep on this I ended up having a neoprene pouch built for a ULXD TX that had elastic arm bands and positioned the pack between the shoulder blades.  Pastor wore his standard d:fine headset.  Worked great.
I've also used choir-type hanging mics (DPA) that were suspended above the baptistry and that worked well.  DPA probably had a lot to do with it sounding good vs lower fidelity options.
Tim Weaver:
Guess I should specify that a wireless solution is less than ideal for us. Several people do the baptisms, not just the pastor and they enter/exit from different sides. Id need at least 4 channels of extra radio mics to do this right. Two on each side, one in the tank and one being put on the next pastor.
Too much potential failure and way too expensive for a very short part of the service.
I do love the PCC idea and I may try one on each side automixed for fidelity.
Matthias McCready:
--- Quote from: Tim Weaver on March 04, 2024, 01:09:09 AM ---
--- End quote ---
With the pickup pattern one might do the trick.  :) Unless your pool is much much larger than I am thinking.
Kevin Maxwell:
--- Quote from: Matthias McCready on March 03, 2024, 03:14:00 PM ---
--- End quote ---
The one baptismal tank death that I am aware of they determined was caused be bad wiring in the heater or pump of the tank. When the pastor grabbed the hardwired mic that was properly grounded he completed the circuit from the eclectically hot tank and died. There was another person in the tank when this happened and they weren't zapped at all.
I would never put any kind of hardwired mic anywhere near a baptismal tank. I my opinion and experience the best way to handle this is just to use a wireless hand held mic with a foam wind screen on it to catch any water splashed and put it on a stand so it is really near the front edge just outside of the tank. If you have a decent sound system this will pickup what you need and if the pastor or whoever is doing the dunking needs to step towards the front of the tank and pick up the mic it won't be a problem. Just don't use a rally expensive mic in case someone drops it in the tank.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
