Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > Lighting Forum
DMX>0-10 installed lighting
Milt Hathaway:
For odd DMX to whatever conversions, these folks will have a way to do it: https://response-box.com/gear/shop/
Tim Weaver:
Another Vote for DFD/Doug Fleenor.
I have a room that just got remodeled and I have a dmx board (Chamsys QuickQ Rack) controlling the stage lights already. It was easy to add the DMX12ANL to the system to control the dimming of the led can lights.
The downside that I didn’t know beforehand is that most modern LED can lights will not turn completely off with 0 volts on the sense line. They go down to about 10 percent brightness and stop.
The old controller (demo’d in the remodel) must have also cut power at the 0V level. I need to fond some dmx controllable relay solution if I want to turn these lights completely off.
Jonathan Kok:
I'm not quite understanding what you're describing. Modern 0-10V dimming doesn't have a normal dimmer, but rather the fixtures are fed a constant voltage, and have a dimmer built into them that is controlled by the 0-10V line. The dimmer will dim, but NOT turn OFF the fixture; you need to cut the voltage to turn them off. This means that any 0-10V to DMX adapter box will NOT allow you to turn OFF the fixtures.
The solution we use is to spec ETC Foundry devices. If possible, we spec the Mini Panels which allow for up to 8 zones per Mini Panel. These require separate line voltage inputs for each zone (or you can have a single line voltage input power multiple zones using jumpers), as it is NOT a breaker panel that will take one high amperage input and split it out to each zone. They also have the smaller Zone Controllers that we use in retrofits where a panel can't be installed. Also has useful things like Fire Panel override inputs.
The Fleenor (and others; Pathway offers one as well) 0-10V adapters are useful for integrating into older rack or wall mount dimmers that had 0-10V control inputs rather than DMX; not so useful for modern 0-10V dimmable fixtures. So if you've got an actual 0-10V DIMMER and not DIMMABLE FIXTURES, then maybe that is the correct solution.
EDIT: Lightronics also makes a DMX-controlled 0-10V panel.
Jonathan Kok:
--- Quote from: Tim Weaver on February 12, 2024, 05:17:49 PM ---Another Vote for DFD/Doug Fleenor.
--- End quote ---
ETC Foundry.
https://www.etcconnect.com/Foundry/
Lightronics:
https://www.lightronics.com/architectural_ballast_drivers_ab0602d.html
Stephen Swaffer:
I guess I wasn't clear. What I have is 0-10V dimmable fixtures-the "dimmers" that were installed actually incorporated a switch plus a 0-10V output for dimming.
The DFD comes closest what I am thinking. I will likely replace the dimmers with simple switches since if the 0-10V is disconnected it puts lights at full brightness-and will allow normal use of the switches most of the time-simply adding in the dmx dimming when dimming is desirable. The only question I need to get the answer to is if the DFD stuff can drive eight 0-10 volt sinking loads in parallel-and the fixture manufacturer can't tell me what that load is-guess its experiment time. So much easier when the design is done correctly before the build.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
