Author Topic: Shure body pack transmitter compatibility  (Read 748 times)
Lee Douglas
  • 47.662615, -116.756954
« on: February 10, 2024, 01:15:17 AM »
Quick question- is a Shure QLXD transmitter compatible with a ULXD receiver and can I use the same channel on a ULXD transmitter, not at the same time?
This space for rent
Brian Jojade
Re: Shure body pack transmitter compatibility
« Reply #1 on: February 10, 2024, 01:51:42 AM »
If you're on the same firmware they should be compatible.
Brian Jojade
Todd Cooke
  • Williamsburg, VA
« Reply #2 on: February 10, 2024, 08:39:27 AM »
They are compatible.  But, you will need to manually tune the QLXD pack as IR sync does not work.
Steve-White
  • Fort Worth
« Reply #3 on: February 10, 2024, 05:34:04 PM »
As well ULXD transmitters are compatible with QLXD receivers - which is nice.
« Last Edit: February 19, 2024, 10:29:22 PM by Steve-White »
Peter Kowalczyk
« Reply #4 on: February 19, 2024, 07:28:49 PM »
As well ULXD transmitters are compatible with ULXD receivers - which is nice.
... did you mean to say that ULXD transmitters are compatible with QLXD receivers?
Steve-White
  • Fort Worth
« Reply #5 on: February 19, 2024, 10:29:53 PM »
That was my intention.  :)
doug johnson2
« Reply #6 on: February 21, 2024, 09:03:06 AM »
The QLD and ULX series are compatible, you just need to tune them manually.  IR sync doesn't work. You do have to make sure the transmitters are running compatible software to the receivers.  You can't update a QLX transmitter with a ULX receiver and vise-versa.
Page created in 0.021 seconds with 22 queries.
