Marketplace - Your Displayed Name Must Be Your Real Full Name To Post In The Marketplace Forum > Marketplace
МА Lighting grandMA3 onPC command wing XT Set with grandMA3 processing unit M
(1/1)
Arturo Cabada:
Brand
МА Lighting
Type
Control Console
Model
grandMA3
Color
Black
The package includes everything in the list below and all in great condition.
Condition - Used!
Included in the Set:
grandMA3 onPC command wing XT - 1
grandMA3 processing unit M -3
Expanding the grandMA3 system is simple with addition of grandMA3 processing units! The grandMA3 processing unit M increases the overall grandMA3 system by 4 096 parameters and enables the system designer to expand the lighting control system in small steps. Besides the powerful CPU for frame-synchronous calculation, the grandMA3 processing unit M additionally offers a Mode2 to expand existing grandMA2 systems by 4 096 parameters.
The grandMA3 processing units are designed for rack mounting and all models are only 2RU, allowing for efficient touring solutions. Each model is equipped with 8 DMX outputs for frame-synchronous DMX output throughout the network. Additional frame-synchronous DMX outputs are available with the addition of grandMA3 xPort Nodes.
grandMA3 processing units offer a perfect system overview on the integrated touchscreen. This easy access to important functions allows for best maintenance if installed in a dedicated rack whilst every function can be monitored from the grandMA3 session.
For larger systems it is suggested to keep the grandMA3 processing units in a centralized position for parameter expansion and to use grandMA3 xPort Nodes to distribute and output the frame-synchronous DMX data.
An onPC wing with real console feeling - you think that is impossible? Take a look at the grandMA3 onPC command wing XT! Experience the grandMA3 onPC console solution with the pre-installed onPC software on the built-in MA motherboard. Just connect a touch screen monitor and you can control 4 096 parameters right on the spot!
So, if you are looking for an extremely versatile control solution for small and medium sized theaters or installations, the grandMA3 onPC command wing XT is the right choice for you. It is also a powerful programming tool for TV/streaming studios as well as houses of worship, and it can also serve as a console for pre-programming and backup scenarios.
Of course, it is built to the same highest quality standards in software and hardware that apply to the entire grandMA3 product line. That means you have a reliable solution when you are on the road, touring or controlling your festival stage. With the command area the grandMA3 onPC command wing XT provides you the closest possible look and feel of the larger grandMA3 consoles!
Do you need a few numbers? You have access to 40 physical playbacks, 16 assignable X-Keys and a dedicated master area. With the grandMA3 onPC command wing XT you directly control the maximum 4 096 parameters of the onPC solutions. Therefore, you have three DMX ports and two Ethernet Gigabit ports for DMX-over-Ethernet protocols.
But we are not finished yet! All inputs and outputs of a grandMA3 console are directly built-in. On the rear panel you will find MIDI, timecode, and DC remote ports to receive and send external signals and trigger actions in your show. Additionally, you can connect up to four monitors to create your individual workspace!
The device will be shipped with Windows IoT - so we can make sure it can get a proper factory reset image if needed.
Please do not forget: The grandMA3 onPC software offers the same feature set as the larger consoles - so there is no compromise on functionality. With the powerful MA Start Show you simply boot the grandMA3 onPC command wing XT and get creative right away!
Features.
onPC wing for real-time control of 4 096 parameters in combination with grandMA3 onPC software pre-installed on a built-in MA motherboard
Command section same as grandMA3 onPC command wing
29 rotary RGB backlit encoder
5 dual encoders
10 motorized 60 mm faders
40 separate playbacks
16 assignable x-keys
2 motorized A/B faders 100mm
1 Level-Wheel
Individually backlit and dimmable silent (clickless) keys
Price is $14k(Price is quick to sell)
Shoot me a PM if interested
PICTURES
https://imgur.com/a/Jo8bmOy
Navigation
[0] Message Index
Go to full version
