Author Topic: Hydrophones -What's the effect of the density used in the compound?  (Read 293 times)
Miguel Dahl
Hi,
A very specific question I've not been able to figure out of, and the question doesn't belong in the in the other groups I guess..
I want to build some high quality hydrophones. I found a recipe for it and what components to be used, and got an understanding why they should be used.
But one thing I can't figure out of is exactly why one would want to use a compound with the same density (specific gravity, SG) as the water?
What happens if I mold the piezo in a compound with a higher or lower density than the water I'm submerging it into? Defraction, refraction etc.. But what happens, what's the result?
« Last Edit: September 28, 2023, 01:07:32 PM by Miguel Dahl »
Stephen Swaffer
Re: Hydrophones -What's the effect of the density used in the compound?
« Reply #1 on: September 28, 2023, 01:19:20 PM »
Speculating a bit-I know that fish/depth finders sometimes will be affected and see thermoclines-temperature differences with slight density changes.  Since they work on reflections I would assume some of the signal is reflected by the density change.  Reflected would imply a loss of sound energy and thus a loss in sensitivity of the mic in your case.
Steve Swaffer
Miguel Dahl
« Reply #2 on: September 28, 2023, 01:27:58 PM »
Ooh, reflections. a sound wave propagating through a medium, meets a medum of higher density, higher frequencies are reflected, or attentuated? That opened up in some sense.
Just like you can hear more of the lower frequencies through a wall, while higher frequencies doesn't carry through because of lower energy.
So, a higher density could mean more reflections = attanuation of higher frequencies.
I think I just understood it, if it's about that.
« Last Edit: September 28, 2023, 01:32:00 PM by Miguel Dahl »
« Reply #3 on: September 28, 2023, 04:07:29 PM »
Just like terminating RF lines with same impedance  to maximize signal transfer....
Mike Caldwell
  • Covington, Ohio
« Reply #4 on: September 28, 2023, 08:43:14 PM »
Sound waves in water will change speed and direction when hitting different water temperatures and densities.
By monitoring the water characteristics submarines can hide in different water layers.
Page created in 0.066 seconds with 19 queries.
