Hi, does Rio 2nd generation have remarkably better noise performance compared to Tio? We do a little test between Tio1608 and Midas DL32, and the Tios actually having quite a bad noise floor performance. Would upgrade to Rio improve the noise in general? Appreciate input from people who have both stagebox and could do a simple test to compare both.
Andrien,
The spec sheets for the Rio1608-D2 and the Tio 1608-D both list Hum & Noise as:
–128 dBu typ., Equivalent Input Noise, Input Gain= Max.
–88 dBu Residual output noise, ST master off.
Based on that alone, I wouldn't expect a difference in noise between the two.
Appears to be a noise spike at around 1kHz in your screen posts plus a harmonic around 2kHz visible above the white noise in the lower -36.8 noise shot.
Were both stage boxes both the same distance from noise sources like computer power supplies, switching amplifiers, LED lights?
Did you verify the gain in your tests was actually +60 and +58 dB?
Was the same source and output impedance used for both tests?
Art
